manchester by the sea
tim909
Post by tim909 » Tue Mar 07, 2017 8:56 pm
Cannot seem to rip this regardless of the program. Makemkv gives:
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '8364032'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_09_1.VOB' at offset '8364032'
The disc is in perfect condition.
tim909
Re: manchester by the sea
Post by tim909 » Tue Mar 07, 2017 9:23 pm
after trying a different drive, it worked
hmmm
MakOwner
Post by MakOwner » Thu Mar 30, 2017 11:53 am
I have the US commercial BD+DVD package and the DVD gives these errors on opening and Title #5 fails to rip, but the movie is title #6.
MakeMKV v1.10.5 linux(x64-release) started
Debug logging enabled, log will be saved as /home/~/MakeMKV_log.txt
Title #1 has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (5 cell(s), 0:10:15)
Title #8 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 was added (1 cell(s), 0:15:59)
Title #11 was added (3 cell(s), 0:05:48)
Title #12 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 was added (1 cell(s), 0:02:01)
Title #16 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 was added (1 cell(s), 0:13:45)
DEBUG: Code 10551311 at NJa!B!mYAzQ,itwR:29405752
DEBUG: Code 0 at NJa!B!mYAzQ,itwR:29406741
DEBUG: Code 0 at tN<p4$HV!-YEW/#y;X:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 18-18 were removed from title end
Title #23 was added (16 cell(s), 2:17:16)
Title #25 was added (16 cell(s), 2:17:16)
Title #27 was added (16 cell(s), 2:17:16)
Title #35 was added (16 cell(s), 2:17:16)
Title #47 was added (16 cell(s), 2:17:16)
Title 1 in VTS 13 is equal to title 1 and was skipped
Post by Woodstock » Thu Mar 30, 2017 1:33 pm
I see informational messages in your log, but no outright errors. Did you get errors when you told it to save the titles?
