Question on removing MVC stream from a MKV
spl147
Post by spl147 »
i ripped all my 3D blurays to MKV, i then decided i didnt want the 3D anymore, so i ran the 3D MKV's through MakeMKV again and un ticked the MVC stream, the resulting files play audio and the video is black screen.
no apps see the MVC stream, except TSmuxer see the 3d-pg-planes in the video stream, but no option to remove them.
anyone know how to remove them from the video stream?
here is a link to a 1 min sample: https://www.dropbox.com/s/jx98aoqw3tksf ... n.mkv?dl=0
here is a screenshot of the TSmuxer info:
here is the media info:
General
Unique ID                                : 184252031181136227884724196466716624494 (0x8A9DA681B3A7D1FAB0F921AF376CC66E)
Complete name                            : /Users/Dave/Dropbox/MKV Test File/Transformers Age of Extinction.mkv
Format version                           : Version 4 / Version 2
File size                                : 254 MiB
Duration                                 : 1mn 0s
Overall bit rate                         : 35.5 Mbps
Movie name                               : Transformers Age of Extinction
Encoded date                             : UTC 2016-12-19 17:31:17
Writing application                      : mkvmerge v9.6.0 ('Slave To Your Mind') 64bit
Writing library                          : libebml v1.3.4 + libmatroska v1.4.5
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 3 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1mn 0s
Bit rate                                 : 32.2 Mbps
Maximum bit rate                         : 35.0 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 (24000/1001) fps
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.647
Stream size                              : 230 MiB (91%)
Audio
Format                                   : TrueHD
Format profile                           : TrueHD+Atmos / TrueHD
Duration                                 : 1mn 0s
Bit rate                                 : 3 279 Kbps
Maximum bit rate                         : 7 662 Kbps
Channel(s)                               : Object Based / 8 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                            :  / 48.0 KHz
Frame rate                               : 1 200.000 fps (40 spf)
Stream size                              : 23.5 MiB (9%)
Text
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Bit rate                                 : 0 bps
Count of elements                        : 0
Stream size                              : 0.00 Byte (0%)
Menu
00:00:00.000                             : en:Chapter 01
Re: Question on removing MVC stream from a MKV
You can use mkvmerge from mkvtoolnix to copy the files without the MVC track, or use something like handbrake to recode the video more efficiently, and it will ignore the MVC track for you. :)
spl147
Post by spl147 »
Woodstock wrote:You can use mkvmerge from mkvtoolnix to copy the files without the MVC track, or use something like handbrake to recode the video more efficiently, and it will ignore the MVC track for you. :)
mkvtoolnix says there is no mvc track, i have ran it through mkvtoolnix, the output file has the same issue as the source
handbrake says the files are not valid
I was referring to running the "3D MKV files" through mkvmerge to remove the track that way, not run the already-processed files through it.
Personally, I've never tried opening an MKV file with MakeMKV, because there are other tools to work with. MakeMKV is to get the video off the disk.
spl147
Post by spl147 »
Woodstock wrote:I was referring to running the "3D MKV files" through mkvmerge to remove the track that way, not run the already-processed files through it.
ah, ok. i already deleted the 3D MKV's and no longer have the discs.
im trying to recover the MKV with the removed MVC track that don't play the video stream.
is there a way to edit the video stream to remove the 3d-pg-planes:32? it is stored in codecprivate i believe
You're WAY past my level of understanding with a question like that. Sorry.
spl147
Post by spl147 »
@mike admin?
spl147
Post by spl147 »
mike?
I'd suggest emailing Mike at support@makemkv.com and giving him a link to this topic. That's the best way to get his attention.
spl147
Post by spl147 »
Woodstock wrote:I'd suggest emailing Mike at support@makemkv.com and giving him a link to this topic. That's the best way to get his attention.
I sent him a PM, he read it but did not respond
