Have been using MKV for a number of years and jus the other day I lost the ability to load a disk to "rip"
Have tried both Blu ray and non blu ray with the same results ...
Insert the disk, the drawer closes on the software application
The disk starts spinning, but, after a period of time the disk just ejects
I have a back up blu ray player and tried that .... With the same results
Usually have connected to a hub (Blu ray player) have connected directly to my USB port on my Mac mini with no change
Neither USB optical player (both MATSHITA) will load the disk if Blu ray .. just spins then eject
Not sure if this is software, or hardware
Check my latest OS updates ... Only update was Apple Remote Desktop Client on 3/15/2017
My last "rip" was on 3/18/2017 of a Blu ray disk ... Australia, with no problems
This started on 3/21/2007
Here is the software showing both players
MakeMKV v1.10.4 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/wileywesson/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HE13d" opened in OS access mode.
Optical drive "BD-RE MATSHITA BD-MLT UJ272 1.01d" opened in OS access mode.
This is the log for both players after insertion of media:
Debug log started at Sat Mar 25 08:24:26 2017 , written by MakeMKV v1.10.4 darwin(x86-release)
001005:0000 MakeMKV v1.10.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/wileywesson/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ272 1.01d" opened in OS access mode.
Debug log started at Sat Mar 25 08:51:47 2017 , written by MakeMKV v1.10.4 darwin(x86-release)
002010:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HE13d" opened in OS access mode.
002010:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ272 1.01d" opened in OS access mode.ode.
Was just able to load a non blu ray and decode to a mkv file using one player .. the other would not work
DVD+R-DL MATSHITA DVD-R UJ-898 HE13d This player will do non blu ray ... but, not blu ray
Debug log started at Sat Mar 25 09:05:32 2017 , written by MakeMKV v1.10.4 darwin(x86-release)
001003:0020 DEBUG: Code 0 at ^u%an[QYXJF9@q2`bc#` Fu*::121263153
003028:0000 Title #1 was added (27 cell(s), 1:37:14)
003028:0000 Title #2 was added (1 cell(s), 0:02:36)
003025:0000 Title #4 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/wileywesson/Movies/_MKV
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Any suggestions would be appreciated
No disc load
Re: No disc load
A DVD player will NOT work with Bluray, but a Bluray player USUALLY also work for DVD.
This is not an MakeMKV issue; it's a limitation of the hardware.
As for the reading BD in the BD drive, what happens if you set your system DATE to the 18th and start MakeMKV?
As for regions, MakeMKV does not "respect" the region coding on BDs, so it should not care about changing regions. I've ripped both region A and B Blurays in the same session, although I've done with LG and Samsung drives, not Matshita.
The logs, however, does not show MakeMKV getting the signal that a disk was inserted; Did the display change to list the disk information in the Info box, like this?
Product: BDDVDRW UH08LS10
Revision: 2.00
Serial number: H9M9B395441
Firmware date: 2009-10-26 12:34:56
Highest AACS version: 62
Disc Information
Label: Kyousougiga Disc 1
Timestamp: 2016-09-27 10:53:22
Data capacity: 44.9 Gb
Disc type: BD-ROM
Number of layers: 2
wessongroup
Re: No disc load
Purchased a new player ... Pioneer BDR-XS06 BD/DVD/CD and everything is fine (DVD and Blu ray)
Have "trashed" the two older ones ...
They seem to last about a 1-1/2 year ... As I have purchased a number of players, which go out after a year or two
The other two, I thought were OK ... They were not
But, thanks for the response
