Moana BluRay - Backup Failed
debugit
Post by debugit »
I've tried cleaning the disc and no luck. It plays fine in my other BluRay players
Output:
MakeMKV v1.10.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log.txt
Backing up disc into folder "d:/bluray/MOANA"
DEBUG: Code 0 at u9v:Uv6y$8nM'j+[Sf$:29396460
DEBUG: Code 0 at =v!7JVOiRSk`bf'k2=$Y:213133319
Backup failed
Debug Log:
Debug log started at Mon Mar 27 23:33:59 2017 , written by MakeMKV v1.10.5 win(x64-release)
001005:0000 MakeMKV v1.10.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log.txt
005072:0000 Backing up disc into folder "d:/bluray/MOANA"
DEBUG: Code 2147483648 at R_A_ojS7W=KRgsN<:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=L9Dgs4PtA1jKS3QEOdYxNm5TknavCXeUYuholSYmK1KlHP65NyqSpJHSyZqeFIfQDIgncea2pC4LUdeeJKrnBpqRoO6jkYj2CvIcI/AZSHGQpXQ1XXIzrrjaUF+xl2bht//uDjS0x5gPgZujEztycrNFBqPSCt20YQ==
DCE=VGjEy30B+7vLZ4hTPj7mA7KBZv6vHFN7QAma+ZK7w2o5z71+iNLLCOHnLevPs9Xd2C9ZrXOkpN0CL2rG/vW9WjJXQYUpeYhqvCIJAvQHV0c9uflz4VpXMXnu5+AuEQRxqkl0Ig6UwAJzR/9BXjJY7qy5OqoSyPuvRQ==
001003:0020 DEBUG: Code 0 at u9v:Uv6y$8nM'j+[Sf$:29396460
001003:0020 DEBUG: Code 0 at =v!7JVOiRSk`bf'k2=$Y:213133319
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Mon Mar 27 23:37:15 2017
What can the debug information reveal about this failure? Thanks!
Re: Moana BluRay - Backup Failed
What results do you get if you use Open and Save to MKV instead of backup?
More information is displayed during the open process, and it will often narrow down which file is the problem. The backup will fail if ANY file isn't readable; Save to MKV will save whatever is readable.
Unless it is failing reading the directory information... :roll:
debugit
Post by debugit »
This is kind of dumb, but the problem was that I had a typo in the output directory. Once I corrected the typo, the disc ripped without any difficulty.
Thanks for the tip @Woodstock, using the 'Open and Save' method helped me see the problem. :D
