episode order
snaykebyte
episode order
#1 Post by snaykebyte » Mon Mar 27, 2017 8:15 pm
I know the subject has been beat on forever, but really, is there a reliable way to identify the correct order of episodes on TV series disks?
Re: episode order
#2 Post by Woodstock » Mon Mar 27, 2017 9:35 pm
You mean, without watching the files?
No. You're at the mercy of the disk authors. Most do reasonable things, some do not.
For example, Funimation and Sentai put the episodes in order about 98% of the time. They screw them up just about the time I stop looking for them to screw it up.
snaykebyte
Re: episode order
#3 Post by snaykebyte » Tue Mar 28, 2017 12:09 am
Acknowledged, thank you.
Reddz144
Re: episode order
#4 Post by Reddz144 » Tue Apr 04, 2017 8:40 pm
Yea i have some ripping to do and i mean alot.always hated this part
being putting it off for a while. I check every episode now i didn't with
one until i notice the metadata didn't match what i were watching
Re: episode order
#5 Post by Woodstock » Tue Apr 04, 2017 10:11 pm
For me, watching the Info window as I scroll down the titles is helpful; when the episode order is screwed up, you'll see the m2ts file names go wacky, like 000015.m2ts followed by 000014.m2ts, then 000012.m2ts, and similar. When it happens on a multi-disk set, the order is USUALLY consistent.
Copy/paste in expert mode is your friend in cases like this. Usually, I'll make sure the NAME is correct, because the file name will then be similar, and rename the files as they're put on the network.
