Allied - - on Linux
MakOwner
Allied - - on Linux
#1 Post by MakOwner » Sat Mar 25, 2017 11:16 pm
Mint MATE desktop: 4.4.0-67-generic #88-Ubuntu SMP Wed Mar 8 16:34:45 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
1.10.4 of MakeMKV.
Rip hasn't finished yet, but I don't anticipate good things. Any fix for this?
Saving 12 titles into directory /home/dale/Videos/Allied
DEBUG: Code 2147483647 at "!?m3NJ'&wsCQglG^I:213131686
DEBUG: Code 2147483647 at "!?m3NJ'&wsCQglG^I:29393930
Error 'Posix error - Unknown error 1073741823' occurred while reading '/dev/sr0' at offset '2196830208'
Unable to open file '/BDMV/STREAM/00800.m2ts' in OS mode due to a bug in OS Kernel. This can be worked around, but read speed may be very slow.
DEBUG: Code 0 at C\E7YZr[zI71.MY+j:121262026
Full run, off to see if the movies plays.
MakeMKV v1.10.4 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dale/MakeMKV_log.txt
File 00800.mpls was added as title #0
Title #00020.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00250.mpls was added as title #1
File 00250.m2ts was added as title #2
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01064.m2ts was added as title #3
File 01065.m2ts was added as title #4
File 01066.m2ts was added as title #5
File 01067.m2ts was added as title #6
File 01068.m2ts was added as title #7
File 01069.m2ts was added as title #8
File 01070.m2ts was added as title #9
File 01071.m2ts was added as title #10
File 01072.m2ts was added as title #11
Title #00022.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
12 titles saved
