Mechanic Resurection
1ChiefsDan
Post by 1ChiefsDan »
There are over 400 files all 19.8 GB. How do you tell which is the correct one? Anyone run into this on other movies?
Re: Mechanic Resurection
Welcome to the world of Lionsgate disks. You will find many of them listed in different topics here.
Do you have the Java Runtime Environment from java.com installed on your computer? If so, MakeMKV can make use of it to try and narrow the list down. It will usually flag one of the titles with "main feature" and put it at the top of the list.
