Letters from Iwo Jima
skippyfx
Post by skippyfx » Fri Mar 24, 2017 4:23 pm
I've cleaned the disc. There appears to be some very minor abrasions. Could that be causing it?
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '8121612288'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8121612288'
Re: Letters from Iwo Jima
Post by Woodstock » Fri Mar 24, 2017 8:07 pm
Anything that makes parts of the disk unreadable will cause read errors. If the scratches are minor, sometimes waxing the disk will "fix" it long enough to read; otherwise, you may have to have it resurfaced.
