I've cleaned the disc. There appears to be some very minor abrasions. Could that be causing it?
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '8121612288'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8121612288'
Letters from Iwo Jima
Re: Letters from Iwo Jima
Anything that makes parts of the disk unreadable will cause read errors. If the scratches are minor, sometimes waxing the disk will "fix" it long enough to read; otherwise, you may have to have it resurfaced.
