Updated MakeMKV?
darksoulvv
Updated MakeMKV?
Went to use the program just now and got what I have seen before: This application version is to old. Please download the latest version
So went to download the newest version, installed it and got the same message again. Then I noticed its the same version as what I had. Will there be a new version later?
walkerhound
Re: Updated MakeMKV?
Same here, no matter what I try I keep getting told I have an old version and ether need to download the new or use a registration key.
MattAF
I'm running into the exact same error message. @mike_admin, do you have anything to fix this?
HankVenture83
Also getting this error. Reinstalled current version and still getting it.
Suggestion: set the date on your computer back to 15 March, and see if the message stops. You can put it back to current once the program starts
The key is SUPPOSED to be good for another week.
Emails to support@makemkv.com will get Mike's attention faster than forum messages.
MakinMeanMKV
I reinstalled the MakeMKV 1.10.4 MS Windows version and when the "This version is too old." dialog popped up, I clicked the [Register] button, then pasted the BETA code copied from the "News and Announcements" page:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
That solved the problem and the application is running again.
jsms99
Woodstock wrote:Suggestion: set the date on your computer back to 15 March, and see if the message stops. You can put it back to current once the program starts
This worked for me, thanks.
technoj
Also, Once this gets fixed, Please add automatic update ability.
yorgo
Beta keys have a limited-use timeframe at which point a new beta key needs to be used. Can't say why the current one stopped given we're a week away from when it's set to expire but if you want to avoid running into this issue permanently, you can always purchase a license.technoj wrote:Also, Once this gets fixed, Please add automatic update ability.
http://makemkv.com/buy/
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
andicole0
Just came across the same problem, worked fine yesterday with 1.10.4 but now saying version is too old, downloaded again - same problem. Will try changing system date.
Andi.
Andi.
The point of an expiring beta key is two-fold. Keep people updating to newer versions, and (the main one) it's less convenient than having a paid, permanent key.
As for automatic updating of the program... Let's just say that the newer version is not always better. If you're using MakeMKV on HD DVDs, you do not want any version newer than 1.10.1, for example, and 1.10.3 has some issues that made it worse than 1.10.2.
I have big issues with auto-updating programs in general.
