Mask of Zorro shows Movie File Only
DataMeister
Post by DataMeister » Tue Mar 14, 2017 6:00 am
The Mask of Zorro DVD has extra content like the trailer and making of featurette, but MakeMKV shows only a single entry for the movie. If I look in Windows file explorer there are definitely lots of files on the disc.
What is going on to prevent the rest of the content from showing?
Re: Mask of Zorro shows Movie File Only
Post by Woodstock » Tue Mar 14, 2017 2:42 pm
What do you have as your minimum size for a title in seconds? The default is 120 (two minutes), which means anything less than that will not be in your selection list.
The log will show this as "skipping title XX".
DataMeister
Post by DataMeister » Tue Mar 14, 2017 3:31 pm
I changed the minimum size to 60 seconds before the original post, just in case, but it made no difference. However the behind the scenes clip is 8 minutes long so that should have shown up regardless. I also checked the full movie clip to see if extra things were tacked on, but it's definitely just the movie.
