Broken video as result convert from vob-file
harryfan
Post by harryfan »
Version 1.5.5 beta. Input vob: http://narod.ru/disk/20735869000/VTS_01_1.VOB.html (743Mb).
Result of conversion is color-squared in many frames and square-form errors on edge of figures.
Probably, error in format conversion.
Source video - cartoone, ntsc
P.S. Sorry for pigin-english :)
Tester
Re: Broken video as result convert from vob-file
Post by Tester »
Yes, I have this problem too.
This is a vob file from original DVD.
When this DVD opened in MakeMKV (last 1.5.5 version) and conversion, mkv from "this file" (and other) is playing, but if mkv-file demux in mpg - video file is wrong and error... (see previous post)
setarip_old
Post by setarip_old »
@harryfan
Hi!
The link you've provided is that of a Slavic (Russian?) language website. Can you provide an English version or translation please?
harryfan
Post by harryfan »
setarip_old wrote:@harryfan
Hi!
Get ftp-link: ftp://213.169.66.125/Video_1/VTS_01_1%5B1%5D.VOB
P.S. Conversion from this vob to mpg another utilites (some is DVTool) and muxing with mkvmerge -> normally video.
harryfan
Post by harryfan »
Tester wrote:Yes, I have this problem too.
Video wrong not after demux. I see broken frames in player with mkv.
davidgreem
Post by davidgreem »
Yes it may be possible that due to improper conversion that hampers the quality of the video or the video file is not compatable with the player.
harryfan
Post by harryfan »
davidgreem wrote:Yes it may be possible that due to improper conversion that hampers the quality of the video or the video file is not compatable with the player.
But another utilite make the conversion without errors. I use dvtool + mkvmerge and got mkv file with video quality, equal source file. Convert by makemkv as result get broken video.
Tester
Post by Tester »
And I used PGCDemux (m2v) and then mkvmerge.
Video in final MKV-file is correct too.
Therefore, problem in MakeMKV "engine" or what else?
Post by mike admin »
Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and send it to support@makemkv.com
Tester
Post by Tester »
mike admin wrote:Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and send it to support@makemkv.com
Letter (with a description of problem) was sent 2010-05-22. But new version 1.5.6 is not a fix this problem :(
