Under the Skin - read issues
husar
Post by husar »
I have tried two different BR copies and the same result. Once the BR is read the actual movie is never found. It is also extremely slow reading compared to other discs. I'd say it was a dirt disc but the same result on two different BR discs it has to be something else. Here is the log and a screen shot of the results.
Once the BR is read the two biggest files are 1.6 GB and 3.4 GB.
Here is the log.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '3078144'
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Title #00800.mpls was skipped
Title #00082.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00451.mpls was added as title #0
Title 00700.mpls is equal to title 00451.mpls and was skipped
File 00470.mpls was added as title #1
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #2
Title #00011.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '129024'
Failed to decode audio/video data for title #3 - invalid mux or internal error, title skipped.
Title #00012.m2ts was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '2488320'
Title #00015.m2ts was skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00277.m2ts was added as title #3
Title #00278.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00279.m2ts was added as title #4
Title #00280.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00281.m2ts was added as title #5
File 00282.m2ts was added as title #6
File 00283.m2ts was added as title #7
File 00284.m2ts was added as title #8
File 00285.m2ts was added as title #9
File 00286.m2ts was added as title #10
File 00287.m2ts was added as title #11
File 00288.m2ts was added as title #12
Title #00289.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00290.m2ts was added as title #13
Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 37 errors of type 'Read Error' - see /errors/read/
Re: Under the Skin - read issues
Did both disks have failures at the same location in the files being ripped, or different areas?
husar
Post by husar »
Woodstock wrote:Did both disks have failures at the same location in the files being ripped, or different areas?
I have both discs so I'm trying the second again to see. I'll post log on a few minutes.
husar
Post by husar »
Here is the log from the second BR of Under the Skin.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '406253568'
Hash check failed for file 00012.m2ts at offset 1173504, file is corrupt.
The source file '/BDMV/STREAM/00012.m2ts' is corrupt or invalid at offset 1327104, attempting to work around
Hash check failed for file 00012.m2ts at offset 1370112, file is corrupt.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '2813952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '61440'
File 00015.m2ts was added as title #3
File 00277.m2ts was added as title #4
File 00279.m2ts was added as title #5
File 00281.m2ts was added as title #6
File 00282.m2ts was added as title #7
File 00283.m2ts was added as title #8
File 00284.m2ts was added as title #9
File 00285.m2ts was added as title #10
File 00286.m2ts was added as title #11
File 00287.m2ts was added as title #12
File 00288.m2ts was added as title #13
File 00290.m2ts was added as title #14
Encountered 20 errors of type 'Read Error' - see /errors/read/
Encountered 2 errors of type 'HashCheck Error' - see /errors/hashcheck/...
I didn't notice this before, but... These read error are occurring during the SCAN phase, rather than during the actual rip, correct?
Do the errors occur if you do a BACKUP instead of using Open/Save ?
husar
Post by husar »
Woodstock wrote:I didn't notice this before, but... These read error are occurring during the SCAN phase, rather than during the actual rip, correct?
Yes, during the read phase on both copies oddly. The movie fokder never is shown infact to select it to be ripped.
I'm attempting to do a backup right now.
husar
Post by husar »
That didn't take very long. They both error out on the copy. Here are the results. Different spots but it seems odd that both discs are bad. Does this just mean that both disc are damaged?
Backing up disc into folder "/Volumes/Plex Media/backup/UNDER_THE_SKIN"
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00017.m2ts' at offset '0'
Backup failed
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '0'
Backup failed
