Backup disc is diabled
Yukiko
Post by Yukiko » Wed Mar 08, 2017 12:45 am
I am using the trial version of the beta and the ability to backup the disc is disabled. Is that a limitation of the trial version? Everything else seems to function. I am experiencing one other strange thing but I'll post that under a different topic later.
Thanks in advance.
Yukiko
Re: Backup disc is diabled
Post by d00zah » Wed Mar 08, 2017 2:17 am
You can use the temporary beta key found here:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
but it will need to be updated periodically.
Lovely Rita
Post by Lovely Rita » Wed Mar 08, 2017 2:44 am
Yukiko wrote:I am using the trial version of the beta and the ability to backup the disc is disabled. Is that a limitation of the trial version?
You didn't mention whether your disc is DVD or Blu-Ray but the back up feature is Blu-Ray only.
Registered User :wink:
Buy MakeMKV
Yukiko
Post by Yukiko » Wed Mar 08, 2017 6:26 am
Thanks d00zah. Will give it a try.
Lovely Rita, I tried both DVD and Blu-Ray. It was disabled for both.
Yukiko
Post by Yukiko » Wed Mar 08, 2017 6:37 am
I entered the key and "Backup" is still Disabled. I did restart the program after entering the key.
Tested on Hilary's America Blu-Ray and Doctor Quinn ?Medicine Woman DVD.
I am running Windows 10. My Blu-Ray drive is an ASUS. Don't know the model but MakeMKV extracts the video files so I don't know why the backup feature would not work.
