Suggestion: Option for no minimum video length
thudman99
I'm working with blurays of old laserdisk games, and find a number of short cut scenes are being omitted because of the 2 second minimum on video length. Can we get that down to Zero?
kjhgshadow
Re: Suggestion: Option for no minimum video length
That option is already in the preferences.
setarip_old
@kjhgshadow
Hi!
If you check carefully, although it initially appears that you can set the minimum time to -0- seconds, you'll discover that it resets to a lowest possible time of 2 seconds...
Hi!
