Version 10.1.4 taking way longer to backup
johng
#1 Post by johng » Sat Mar 04, 2017 4:14 am
It used to take only ~30 minutes to make an unecrypted backup of a movie, but 10.1.4 is taking me 2-3 hours? Is anyone else seeing this as I haven't changed anything in my setup.
Lovely Rita
Re: Version 10.1.4 taking way longer to backup
#2 Post by Lovely Rita » Sat Mar 04, 2017 4:19 am
No change for me. :wink:
Registered User :wink:
Buy MakeMKV
yorgo
#3 Post by yorgo » Sat Mar 04, 2017 11:57 am
Like Lovely Rita, I am also not experiencing this problem. I have a Windows 10 system; what are you using?
johng
#4 Post by johng » Sat Mar 04, 2017 3:14 pm
OK if others aren't seeing this must be something on my end. I'll look to see what else might have changed.
#5 Post by Woodstock » Sat Mar 04, 2017 3:21 pm
The few times I've used Backup, the speed was highly variable, just like when using my normal Open/Save to MKV. Some disks are SLOW to rip. While I often see 3-8x speeds while ripping, a few recent disks have been hard pressed to hit 2x, with no real explanation as to why.
It MAY be that they're having high retry rates; When the drive does a retry, it doesn't always report it to the operating system.
RocketMKV
#6 Post by RocketMKV » Fri Mar 10, 2017 5:37 am
Much slower for me as well. I was forced to upgrade to 10.1.4 and now it's unusable as it reports several hours for one disk.
To troubleshoot, I've created a clone of the actual disk in memory. (Using Virtual CloneDrive) MakeMKV is reading the clone disk and has the same problems as the real disk.
Currently, it is reporting a read rate of 395K/s (0.2X), Elapsed 0:13:52, Remaining 3:25:07. My CPU is at 8%.
I would expect it to work very quickly reading from the clone and not hampered by a slow read of DVD drive.
Edit. An hour after I posted the issue, I tried a different disk and it worked fine.
I can only guess that the data was different. Both were normal DVD's as far as I know.
I'm in the process of converting my DVD's into MKV's and storing them on an External HD.
I would like to try running 10.1.3 again to see if truly, one version is different, but I can't.
#7 Post by Woodstock » Fri Mar 10, 2017 3:19 pm
You can get older versions here: /download/old/
The current beta key will work with the older versions, but you may have to set your system date back long enough to get the older version to let you enter the new key.
RocketMKV
#8 Post by RocketMKV » Tue Mar 14, 2017 10:46 am
Thank you very kindly. So far so good with 10.1.4. I've done several since. Probably something in the data file of the one that didn't work.
