SystemDisc
Posts: 8 Joined: Mon Jan 09, 2017 3:14 am
Post
by SystemDisc » Fri Mar 03, 2017 2:44 pm
The error is as follows:
MakeMKV v1.10.4 darwin(x86-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.01d" opened in OS access mode.
Title #1 was added (44 cell(s), 2:09:47)
Title #2 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (1 cell(s), 0:02:24)
Title #7 was added (1 cell(s), 0:02:30)
Title #8 was added (1 cell(s), 0:02:18)
Title #9 was added (1 cell(s), 0:04:53)
Title #10 was added (7 cell(s), 0:17:34)
Title #11 was added (1 cell(s), 0:03:16)
Title #12 was added (1 cell(s), 0:02:08)
Saving 1 titles into directory /Users/systemdisc/NAS/remux/ADVDTITLE
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '37748736'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk1' at offset '37748736'
Failed to save title 0 to file /Users/systemdisc/NAS/remux/ADVDTITLE/title00.mkv
Encountered 11 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
0 titles saved, 1 failed
I am using an external drive which is powered and has a very short USB 3.X cable. I do not have this issue on Windows with this drive. The error seems to happen when MakeMKV is almost finished with the main title.
SystemDisc
Post
by SystemDisc » Fri Mar 03, 2017 3:42 pm
Here is the debug log from another attempt with the same DVD:
Debug log started at Fri Mar 3 14:49:27 2017 , written by MakeMKV v1.10.4 darwin(x86-release)
001005:0000 MakeMKV v1.10.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/systemdisc/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.01d" opened in OS access mode.
003028:0000 Title #1 was added (44 cell(s), 2:09:47)
003025:0000 Title #2 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #6 was added (1 cell(s), 0:02:24)
003028:0000 Title #7 was added (1 cell(s), 0:02:30)
003028:0000 Title #8 was added (1 cell(s), 0:02:18)
003028:0000 Title #9 was added (1 cell(s), 0:04:53)
003028:0000 Title #10 was added (7 cell(s), 0:17:34)
003028:0000 Title #11 was added (1 cell(s), 0:03:16)
003028:0000 Title #12 was added (1 cell(s), 0:02:08)
001003:0020 DEBUG: Code 233 at KmvQIA7y47Ak2sRouVWKwCSZ:0
005014:0000 Saving 1 titles into directory /Users/systemdisc/NAS/remux/ADVDTITLE
001003:0020 DEBUG: Code 1073741829 at "|H?2N %8cDnU=J7:29393953
001003:0020 DEBUG: Code 100941314 at R!uHv<o_rR:g@!5):121269731
001003:0020 DEBUG: Code 100864261 at R!uHv<o_rR:g@!5):121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '5106608128'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '5106608128'
DEBUG: Code 1073741829 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 1073741829 at RT>0\^Fe?{:c[sc./F:121262969
DEBUG: Code 100864261 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 100864261 at RT>0\^Fe?{:c[sc./F:121262969
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '5106608128'
DEBUG: Code 100941314 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 100941314 at RT>0\^Fe?{:c[sc./F:121262969
001003:0020 DEBUG: Code 0 at 3(WCQn/XbnJ/7(ZK_syF:213131387
001003:0020 DEBUG: Code 0 at +nXcji4[F[$WfLu]Dwi:213129938
001003:0020 DEBUG: Code 0 at 3(WCQn/XbnJ/7(ZK_syF:29394459
001003:0020 DEBUG: Code 2493461 at 3(WCQn/XbnJ/7(ZK_syF:121261497
001003:0020 DEBUG: Code 0 at ut37.2!aXpNS(t(`DD<ET:213135297
001003:0020 DEBUG: Code 0 at a%`X9gU.K5BpnMr'_RP:213132882
RH2=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
FS ID=<FAILED> C=0
TI=ZeNpjZBg4wMzI8ABEAwAFhwDm
001003:0020 DEBUG: Code 0 at !T9PJ}ojg[2@L/2c0:213131893
001003:0020 DEBUG: Code 0 at !T9PJ}ojg[2@L/2c0:121263406
001003:0020 DEBUG: Code 0 at !T9PJ}ojg[2@L/2c0:29393907
005003:0000 Failed to save title 0 to file /Users/systemdisc/NAS/remux/ADVDTITLE/title00.mkv
002023:0000 Encountered 50 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=50 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 53 unclassified errors
error=0x06043E02 count=12 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
error=0x40000005 count=41 name=Posix error - Input/output error
005004:0080 0 titles saved, 1 failed
Posts: 10938 Joined: Sun Jul 24, 2011 11:21 pm
Post
by Woodstock » Fri Mar 03, 2017 3:52 pm
One thing you can try is dropping back to 1.10.2 (available at /download/old/ if you didn't keep a copy) and doing the rip. Some people have reported issues with .3 and .4 (especially 1.10.3) that go away with earlier versions. There haven't been many, but... it's worth checking.
SystemDisc
Post
by SystemDisc » Fri Mar 03, 2017 4:50 pm
Thanks! I'll give it a shot after work.
