SystemDisc
#1
Post
by SystemDisc » Fri Mar 03, 2017 2:44 pm
The error is as follows:
MakeMKV v1.10.4 darwin(x86-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.01d" opened in OS access mode.
Title #1 was added (44 cell(s), 2:09:47)
Title #2 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (1 cell(s), 0:02:24)
Title #7 was added (1 cell(s), 0:02:30)
Title #8 was added (1 cell(s), 0:02:18)
Title #9 was added (1 cell(s), 0:04:53)
Title #10 was added (7 cell(s), 0:17:34)
Title #11 was added (1 cell(s), 0:03:16)
Title #12 was added (1 cell(s), 0:02:08)
Saving 1 titles into directory /Users/systemdisc/NAS/remux/ADVDTITLE
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '37748736'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk1' at offset '37748736'
Failed to save title 0 to file /Users/systemdisc/NAS/remux/ADVDTITLE/title00.mkv
Encountered 11 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
0 titles saved, 1 failed
I am using an external drive which is powered and has a very short USB 3.X cable. I do not have this issue on Windows with this drive. The error seems to happen when MakeMKV is almost finished with the main title.
SystemDisc
#2
Post
by SystemDisc » Fri Mar 03, 2017 3:42 pm
Here is the debug log from another attempt with the same DVD:
Debug log started at Fri Mar 3 14:49:27 2017 , written by MakeMKV v1.10.4 darwin(x86-release)
001005:0000 MakeMKV v1.10.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/systemdisc/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.01d" opened in OS access mode.
003028:0000 Title #1 was added (44 cell(s), 2:09:47)
003025:0000 Title #2 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #6 was added (1 cell(s), 0:02:24)
003028:0000 Title #7 was added (1 cell(s), 0:02:30)
003028:0000 Title #8 was added (1 cell(s), 0:02:18)
003028:0000 Title #9 was added (1 cell(s), 0:04:53)
003028:0000 Title #10 was added (7 cell(s), 0:17:34)
003028:0000 Title #11 was added (1 cell(s), 0:03:16)
003028:0000 Title #12 was added (1 cell(s), 0:02:08)
001003:0020 DEBUG: Code 233 at KmvQIA7y47Ak2sRouVWKwCSZ:0
005014:0000 Saving 1 titles into directory /Users/systemdisc/NAS/remux/ADVDTITLE
001003:0020 DEBUG: Code 1073741829 at "|H?2N %8cDnU=J7:29393953
001003:0020 DEBUG: Code 100941314 at R!uHv<o_rR:g@!5):121269731
001003:0020 DEBUG: Code 100864261 at R!uHv<o_rR:g@!5):121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '5106608128'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '5106608128'
DEBUG: Code 1073741829 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 1073741829 at RT>0\^Fe?{:c[sc./F:121262969
DEBUG: Code 100864261 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 100864261 at RT>0\^Fe?{:c[sc./F:121262969
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '5106608128'
DEBUG: Code 100941314 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 100941314 at RT>0\^Fe?{:c[sc./F:121262969
001003:0020 DEBUG: Code 0 at 3(WCQn/XbnJ/7(ZK_syF:213131387
001003:0020 DEBUG: Code 0 at +nXcji4[F[$WfLu]Dwi:213129938
001003:0020 DEBUG: Code 0 at 3(WCQn/XbnJ/7(ZK_syF:29394459
001003:0020 DEBUG: Code 2493461 at 3(WCQn/XbnJ/7(ZK_syF:121261497
001003:0020 DEBUG: Code 0 at ut37.2!aXpNS(t(`DD<ET:213135297
001003:0020 DEBUG: Code 0 at a%`X9gU.K5BpnMr'_RP:213132882
RH2=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
FS ID=<FAILED> C=0
TI=ZeNpjZBg4wMzI8ABEAwAFhwDm
001003:0020 DEBUG: Code 0 at !T9PJ}ojg[2@L/2c0:213131893
001003:0020 DEBUG: Code 0 at !T9PJ}ojg[2@L/2c0:121263406
001003:0020 DEBUG: Code 0 at !T9PJ}ojg[2@L/2c0:29393907
005003:0000 Failed to save title 0 to file /Users/systemdisc/NAS/remux/ADVDTITLE/title00.mkv
002023:0000 Encountered 50 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=50 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 53 unclassified errors
error=0x06043E02 count=12 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
error=0x40000005 count=41 name=Posix error - Input/output error
005004:0080 0 titles saved, 1 failed
#3
Post
by Woodstock » Fri Mar 03, 2017 3:52 pm
One thing you can try is dropping back to 1.10.2 (available at /download/old/ if you didn't keep a copy) and doing the rip. Some people have reported issues with .3 and .4 (especially 1.10.3) that go away with earlier versions. There haven't been many, but... it's worth checking.
SystemDisc
#4
Post
by SystemDisc » Fri Mar 03, 2017 4:50 pm
Thanks! I'll give it a shot after work.
