Broken video as result convert from vob-file
harryfan
#1 Post by harryfan » Sun May 16, 2010 10:42 pm
Version 1.5.5 beta. Input vob: http://narod.ru/disk/20735869000/VTS_01_1.VOB.html (743Mb).
Result of conversion is color-squared in many frames and square-form errors on edge of figures.
Probably, error in format conversion.
Source video - cartoone, ntsc
P.S. Sorry for pigin-english :)
Tester
Re: Broken video as result convert from vob-file
#2 Post by Tester » Mon May 17, 2010 12:11 am
Yes, I have this problem too.
This is a vob file from original DVD.
When this DVD opened in MakeMKV (last 1.5.5 version) and conversion, mkv from "this file" (and other) is playing, but if mkv-file demux in mpg - video file is wrong and error... (see previous post)
setarip_old
#3 Post by setarip_old » Mon May 17, 2010 3:13 am
@harryfan
Hi!
The link you've provided is that of a Slavic (Russian?) language website. Can you provide an English version or translation please?
harryfan
#4 Post by harryfan » Mon May 17, 2010 8:58 am
setarip_old wrote:@harryfan
Hi!
Get ftp-link: ftp://213.169.66.125/Video_1/VTS_01_1%5B1%5D.VOB
P.S. Conversion from this vob to mpg another utilites (some is DVTool) and muxing with mkvmerge -> normally video.
harryfan
#5 Post by harryfan » Mon May 17, 2010 9:08 am
Tester wrote:Yes, I have this problem too.
Video wrong not after demux. I see broken frames in player with mkv.
davidgreem
#6 Post by davidgreem » Tue May 18, 2010 2:27 pm
Yes it may be possible that due to improper conversion that hampers the quality of the video or the video file is not compatable with the player.
harryfan
#7 Post by harryfan » Wed May 19, 2010 10:06 am
davidgreem wrote:Yes it may be possible that due to improper conversion that hampers the quality of the video or the video file is not compatable with the player.
But another utilite make the conversion without errors. I use dvtool + mkvmerge and got mkv file with video quality, equal source file. Convert by makemkv as result get broken video.
Tester
#8 Post by Tester » Wed May 19, 2010 4:21 pm
And I used PGCDemux (m2v) and then mkvmerge.
Video in final MKV-file is correct too.
Therefore, problem in MakeMKV "engine" or what else?
#9 Post by mike admin » Sat May 22, 2010 7:44 am
Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and send it to support@makemkv.com
Tester
#10 Post by Tester » Thu May 27, 2010 6:58 pm
mike admin wrote:Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and send it to support@makemkv.com
Letter (with a description of problem) was sent 2010-05-22. But new version 1.5.6 is not a fix this problem :(
