Version 1.5.5 beta. Input vob: http://narod.ru/disk/20735869000/VTS_01_1.VOB.html (743Mb).
Result of conversion is color-squared in many frames and square-form errors on edge of figures.
Probably, error in format conversion.
Source video - cartoone, ntsc
P.S. Sorry for pigin-english
Broken video as result convert from vob-file
Re: Broken video as result convert from vob-file
Yes, I have this problem too.
This is a vob file from original DVD.
When this DVD opened in MakeMKV (last 1.5.5 version) and conversion, mkv from "this file" (and other) is playing, but if mkv-file demux in mpg - video file is wrong and error... (see previous post)
@harryfan
Hi!
The link you've provided is that of a Slavic (Russian?) language website. Can you provide an English version or translation please?
Hi!
Get ftp-link: ftp://213.169.66.125/Video_1/VTS_01_1%5B1%5D.VOBsetarip_old wrote:@harryfan
Hi!
P.S. Conversion from this vob to mpg another utilites (some is DVTool) and muxing with mkvmerge -> normally video.
Video wrong not after demux. I see broken frames in player with mkv.Tester wrote:Yes, I have this problem too.
Yes it may be possible that due to improper conversion that hampers the quality of the video or the video file is not compatable with the player.
But another utilite make the conversion without errors. I use dvtool + mkvmerge and got mkv file with video quality, equal source file. Convert by makemkv as result get broken video.davidgreem wrote:Yes it may be possible that due to improper conversion that hampers the quality of the video or the video file is not compatable with the player.
And I used PGCDemux (m2v) and then mkvmerge.
Video in final MKV-file is correct too.
Therefore, problem in MakeMKV "engine" or what else?
- Contact:
Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and send it to support@makemkv.com
Letter (with a description of problem) was sent 2010-05-22. But new version 1.5.6 is not a fix this problemmike admin wrote:Please enable debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and send it to support@makemkv.com
