Hacksaw Ridge
czmartinez
Re: Hacksaw Ridge
Post by czmartinez »
New Disc, Just Ripped RB 760 with NO issues. Thanks all for the help!
QWERTYMac
Re: Hacksaw Ridge
Post by QWERTYMac »
Lovely Rita wrote:Here's what makemkv shows (RB version) and what others have made reference to in earlier posts.
In my opinion the javascript that Mike developed has become more accurate over time. The last few Lionsgate discs have been on the nose. :wink:
Excuse me, but what kind of blu-ray reader do you have?
I'm looking for a new one with BD-J
Fortissimo
Re: Hacksaw Ridge
Post by Fortissimo »
Anyone know what the correct playlist is for the Netflix version? #760 produces the following segment map:
515,513,503,510,505,506,508,504,502,501,514,509,520,518,516,517,512,507
This apparently does not match the Redbox version :(
boonetyler
Re: Hacksaw Ridge
Post by boonetyler »
Fortissimo wrote:Anyone know what the correct playlist is for the Netflix version? #760 produces the following segment map:
That looks like the right SM
Fortissimo
Re: Hacksaw Ridge
boonetyler wrote:That looks like the right SM
Oops, you're right. I was looking at the SM of 0001 (the original post) - I guess in reading the entire thread, I forgot that the OP wasn't about 0760. :oops:
kihilind
Re: Hacksaw Ridge
Post by kihilind »
I used 760 for my US BR Netflix copy and it's good.
Gotterdamerung
Re: Hacksaw Ridge
Post by Gotterdamerung »
I tried the 760 on my Netflix BR version - and unfortunately about 10 minutes into it I got the black screen warning that this isn't a valid copy.......
Usually the MakeMKV FPL MainFeature works really well for me... but not sure what's happening on this particular one.
Re: Hacksaw Ridge
What are you playing it with? Some players respect the Cinavia copy protection, which MakeMKV doesn't do anything about. The solution is to use a player that doesn't implement Cinavia.
Gotterdamerung
Re: Hacksaw Ridge
Woodstock - thanks for the response. I was using Kodi 17.0 to play it back. To the best of my knowledge Kodi doesn't enforce or detect Cinavia. I will admit - it's possible that this has changed, but so far I haven't run into any other Cinavia issues on Kodi with other movies. So I'm definitely stumped on this one. I'm going to try again using handbrake and perhaps another player like VLC. But this one is certainly baffling to me so any thoughts or advice is appreciated.
richhlo1021
Re: Hacksaw Ridge
Post by richhlo1021 »
mito118 wrote:
czmartinez wrote:Any clue on the Redbox Version?
AnyDVD says that it is playlist 760.
Correct: Watched side-by-side
Name: Hacksaw Ridge (2016) (English)
Comment: FPL_MainFeature
Source file name: 00760.mpls
Duration: 2:19:19
Chapters count: 16
Segment count: 18
Segment map: 515,513,503,510,505,506,508,504,502,501,514,509,520,518,516,517,512,507
File name: Hacksaw_Ridge_(2016)_t01.mkv
goaliebob99
Re: Hacksaw Ridge
Post by goaliebob99 »
I bought the Ultra 4K Bluray version that comes with the normal bluray, and this is the segment map for that disk.
Source file name: 00377.mpls
Duration: 2:19:19
Chapters count: 16
Segment count: 20
Segment map: 509,513,502,514,520,517,508,505,515,501,506,503,516,519,512,504,507,518,510,511
File name: Hacksaw_Ridge_t00.mkv
colsanders83
Re: Hacksaw Ridge
Post by colsanders83 »
Looking to rip the retail version and I see two 'highlighted' listings. One says "FPL_MainFeature" and the other says "SPBD Copy Disclaimer Playlist". My question is what is that second one? The segments orders for the two are different and the "Copy Disclaimer" one has an extra segment.
aukevin
Re: Hacksaw Ridge
Post by aukevin »
I've never seen makemkv tag the main feature. I have Windows version 1.10.4. Is there something special I have to do to see that?
Re: Hacksaw Ridge
You must have the Java Runtime Environment (JRE) from java.com installed. This is NOT required to run MakeMKV itself, just to enable it to look for the correct title on these obfuscated disks. It is not always correct, though.
aukevin
Re: Hacksaw Ridge
Post by aukevin »
Woodstock wrote:You must have the Java Runtime Environment (JRE) from java.com installed. This is NOT required to run MakeMKV itself, just to enable it to look for the correct title on these obfuscated disks. It is not always correct, though.
Great, thank you. I've got it all set correctly now.
