Navigation Error
Stoker
Navigation Error
Post by Stoker »
Hi guys,
I´m getting the following errer when I try to copy one certain DVD:
The debug log tells me:
Debug log started at Wed Feb 22 05:32:19 2017 , written by MakeMKV v1.10.4 win(x64-release)
001005:0000 MakeMKV v1.10.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\570K3R/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
001003:0020 DEBUG: Code 1 at @BZ;nW%fV>yqze:29404717
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
001003:0020 DEBUG: Code 1 at @BZ;nW%fV>yqze:29395333
001003:0020 DEBUG: Code 0 at 0N/mOA"fqdr\KuIVl:29393953
001003:0020 DEBUG: Code 3 at 'saSEs+ #z-&d|1c>:29395034
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003010:0000 Can't locate a cell for VTS 1 TTN 1 PGCN 0 PGN 0
003019:0000 Cells 8-end were skipped due to cell commands (structure protection?)
003024:1000 Complex multiplex encountered - 3 cells and 6793 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
001003:0020 DEBUG: Code 100864261 at ykyW$as]>= |YC]D:121269731
001003:0020 DEBUG: Code 2068218 at y$his,C:uDFr>%L\:121263383
001003:0020 DEBUG: Code 0 at LFo-%0a%XM!F`$)3|K:121273457
001003:0020 DEBUG: Code 0 at LFo-%0a%XM!F`$)3|K:29406879
003015:0000 Title #1 (1:48:41) was skipped due to navigation error
Title skip vts=1 pgcn=1 hash=8284492EA850CE90
003025:0000 Title #2 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Application exited at Wed Feb 22 05:39:21 2017
I use MakeMKV for several Yeaars now, but I never had such Problem. Could you please help me?
Re: Navigation Error
The debug codes mean that MakeMKV encountered unexpected data when it was reading parts of the disk, and is trying to work around it. The question is why it got unexpected data. If the unexpected data said where to find a particular file or its parts, it can cause a navigation error.
Based on comments Mike made a year or so ago, some drives will not report an error if they can "almost" read a sector; they'll simply return what they were able to read, and hope you don't notice. This can be a cause of the unexpected data. And "almost" reads are often caused by dirty or scratched disks, which is why cleaning the disk is the first step in debugging.
Without knowing the disk, none of us can say whether it is one that others have decoded successfully or not.
