Hacksaw Ridge
				angelgraves13
Hacksaw Ridge
Anyone know the correct playlist?
						Re: Hacksaw Ridge
Retail Version
Title information
Source file name: 00001.mpls
Duration: 2:19:19
Chapters count: 16
Segment count: 20
Segment map: 509,513,502,514,520,517,508,505,515,501,506,503,516,519,512,504,507,518,510,511
File name: Hacksaw_Ridge_t00.mkv
Might be 00411.mpls for another version. The segment map is correct.
													Title information
Duration: 2:19:19
Chapters count: 16
Segment count: 20
				CIR Engineering
Re: Hacksaw Ridge
Thank you for posting the segment map. I have been meaning to sign up to this forum for a while, but your post was so helpful that I finally did it.hvnphoto wrote:Retail Version
Title information
Duration: 2:19:19
Chapters count: 16
Segment count: 20
Might be 00441.mpls for another version. The segment map is correct.
Kind regards,
craigr
				CIR Engineering
Re: Hacksaw Ridge
Also looks like playlists 00001.mpls and 00377.mpls matches on mine.
non
						non
Re: Hacksaw Ridge
377 is what I get.  US Retail version.
						Re: Hacksaw Ridge
Anyone have an idea for Hacksaw Ridge Redbox Version?
				czmartinez
Re: Hacksaw Ridge
Any clue on the Redbox Version?
						Re: Hacksaw Ridge
AnyDVD says that it is playlist 760.czmartinez wrote:Any clue on the Redbox Version?
				sweakley2012
Re: Hacksaw Ridge
Still looking for playlist for redbox Blu-ray version.  Anyone solved this one yet?
						Re: Hacksaw Ridge
I am a little confused why you would ask. Not trying to be negative, but at least for me, MakeMKV tells me which one is the feature film in the most current version with this title.czmartinez wrote:Any clue on the Redbox Version?
Re: Hacksaw Ridge
There are about 100+ "feature" files, all with varying segment maps.  None of the previous posts list information consistent with what is on the redbox version.  I'd post the correct answer myself if I knew how to find it.
-Cliff
						-Cliff
Re: Hacksaw Ridge
In my copy of MakeMKV it lists all of the versions yes, but at the top it shows the ones it has identified as the feature as well as the trailers and other things. In this case yes, the Redbox version was 760 as the other poster stated. But MakeMKV showed me this without me having to do anything.
						Re: Hacksaw Ridge
theonegod wrote:In my copy of MakeMKV it lists all of the versions yes, but at the top it shows the ones it has identified as the feature as well as the trailers and other things. In this case yes, the Redbox version was 760 as the other poster stated. But MakeMKV showed me this without me having to do anything.
760 does not work even though it says main feature.
Re: Hacksaw Ridge
Based on what? Seems to work for me.Paratel wrote:theonegod wrote:In my copy of MakeMKV it lists all of the versions yes, but at the top it shows the ones it has identified as the feature as well as the trailers and other things. In this case yes, the Redbox version was 760 as the other poster stated. But MakeMKV showed me this without me having to do anything.
