Moonlight Correct Playlist
angelgraves13
#1 Post by angelgraves13 » Tue Feb 21, 2017 4:14 pm
Does anyone know the correct playlist?
Seems more and more releases are having this issue, and MakeMKV is no help in specifying the correct playlist like AnyDVD. Hopefully a future version will simply hide incorrect playlists.
hvnphoto
Re: Moonlight Correct Playlist
#2 Post by hvnphoto » Tue Feb 21, 2017 7:57 pm
angelgraves13 wrote:Does anyone know the correct playlist?
Seems more and more releases are having this issue, and MakeMKV is no help.
U.S. Retail
PLAYLIST REPORT:
yorgo
#3 Post by yorgo » Wed Feb 22, 2017 12:10 pm
angelgraves13 wrote:Seems more and more releases are having this issue, and MakeMKV is no help.
It's not an "issue", it's called "copy protection", specifically "playlist obfuscation", and was designed for this exact reason :wink:
angelgraves13
#4 Post by angelgraves13 » Wed Feb 22, 2017 2:12 pm
I'm aware of what it is and its purpose. My issue is that MakeMKV doesn't specify the correct playlist like AnyDVD does.
#5 Post by Woodstock » Wed Feb 22, 2017 2:47 pm
If you have Java installed, MakeMKV will try to find the correct play list. If not, it won't, since Java is required for that feature.
hvnphoto
#6 Post by hvnphoto » Fri Feb 24, 2017 4:18 am
U.S. Retail
Title information
Source file name: 00865.mpls
Duration: 1:50:56
Chapters count: 16
Segment count: 20
Segment map: 518,501,519,507,503,512,504,514,515,502,516,505,520,511,508,510,506,509,513,517
File name: Moonlight_t338.mkv
Netflix and Redbox should be the same.
thedigitalhobo
#7 Post by thedigitalhobo » Tue Feb 28, 2017 5:45 pm
If you install the required plug-ins, it works just fine. Don't be lazy. Read the instructions.
Title information
Comment: FPL_MainFeature <<<<<<Right there
Duration: 1:50:56
Chapters count: 16
Segment count: 20
bretb
#8 Post by bretb » Wed Mar 01, 2017 1:51 am
Thanks to you guys who post the playlist info (specifically the segment order).
I'll admit that I'd love to figure out how to determine the correct play list, but all of the procedures that I've followed do not end up with the result that the authors claim should be.
Anyway, I'm sure I'm doing something wrong and not realizing it. Would just be nice to figure it out and feel somewhat self-reliant in this pursuit. :)
Bret
bretb
#9 Post by bretb » Wed Mar 01, 2017 1:52 am
thedigitalhobo wrote:If you install the required plug-ins, it works just fine. Don't be lazy. Read the instructions.
Not being lazy...I've never heard of the plugin (but I'm not on this forum every day either).
What is the plugin called? I gather that it requires Java, but is the plugin put out by the makers of MakeMKV? Where do you download the plugin?
Thanks in advance,
Bret
#10 Post by Woodstock » Wed Mar 01, 2017 2:19 am
Java is provided by Oracle, and you download it from java.com . You need the Java Runtime Environment (JRE). It's free.
Just make sure you do NOT allow JRE to install any integration with your web browsers. While Java is a valuable tool for some things, it is also subject to the "exploit of the week" if it has access to internet. Homeland Security has stopped warning people to remove it if they aren't using it, but it still has issues to this day.
billbillw
#11 Post by billbillw » Wed Mar 01, 2017 2:23 am
Make sure you have 64-bit Java installed. If you do, MakeMKV will tell you that 865.mpls is the FPL_Main Feature for the redbox version.
I'm not sure if that is correct or not, but it is at least trying to determine.
colgate2004
Moonlight Netflix version FPL_MainFeature is wrong
#12 Post by colgate2004 » Thu Mar 02, 2017 2:58 pm
Hi all,
I want to let the community know, the "FPL_MainFeature" recommended playlist for the Moonlight Netflix version (640.mpls) is wrong.
I don't know what the correct mpls is (I'm not set up to do the necessary investigating to figure it out), but I sat down to watch 640.mpls and there were a bunch of scenes out of order.
(The segment map for 640.mpls, which is wrong, is 518,501,519,507,503,514,506,516,508,515,520,513,504,509,502,512,510,511,505,517.)
colgate2004
#13 Post by colgate2004 » Thu Mar 02, 2017 3:06 pm
Also, I just found that the Netflix version 865.mpls has the same segment map as the retail version 865.mpls that others have posted above, so it's possible that that is the correct list on the Netflix version as well.
Not certain, but possible.
#14 Post by Woodstock » Thu Mar 02, 2017 3:28 pm
If you're not getting the correct playlist for a disk, Mike said to see: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330
mmaslar
#15 Post by mmaslar » Sun Apr 09, 2017 4:13 pm
FYI... PowerDVD and Process Monitor give me 00835.mpls while MakeMKV shows 00865.mpls as the main feature.
