How to rip 3D movies in my HDD to use with Oppo-103
sharok
Post by sharok » Fri Feb 17, 2017 5:33 pm
Would you please instruct me on how to rip 3D movies to my hard drive so I can watch them using Oppo-103?
The Oppo tech support told me about side by side and top to bottom, but I do not know how to setup makemkv to do that.
I'm totally clueless and I need your instructions on how to do that.
Thank you in advance for your help.
Re: How to rip 3D movies in my HDD to use with Oppo-103
Post by Woodstock » Fri Feb 17, 2017 8:14 pm
You have to make sure you're ripping the 3D MVC track when you rip a 3D source. That is not automatic; You need to click on the little triangle next to the title in the left menu, and make sure there is a check box next to the "3D MVC" track.
This assumes you're ripping to MKV files; If you are using "Backup", the track is automatically included.
Beyond that, it's up to the Oppo to play that track correctly.
sharok
Post by sharok » Sat Feb 18, 2017 12:00 am
That is the problem. Oppo does not play MVC.
Post by Woodstock » Sat Feb 18, 2017 3:14 am
There are a lot of messages about this on the forum, but... the keywords to search for are too short to index, so they aren't easy to find. And there isn't a single message or thread out there contains enough information to make it "sticky" and easy to find. :roll:
Some that might answer your question:
http://makemkv.com/forum2/viewtopic.php?f=1&t=6081 3D Blu-Rays - A Guide!
http://makemkv.com/forum2/viewtopic.php?f=1&t=14744 3D MVC Recognized then Unrecognized by TV
http://makemkv.com/forum2/viewtopic.php?f=1&t=14598 Can't create Full SBS 3D mkv from my BluRay Avatar
sharok
Post by sharok » Sat Feb 18, 2017 6:49 am
Thanks for the directions.
It seems to be easier to just play the 3D disk than ripping it to HDD.
