seaQuest Season 1 German Blu-ray Release - Disc 2
preserve
#1 Post by preserve » Fri Feb 17, 2017 9:33 am
I've had two copies of this release, and both times, I have the exact same error on Disc 2.
I have no errors with my drive, I ripped discs without problem before and after this.
I always rip my discs as soon as I get them to ensure they're okay. Up until now, this method always worked without fail. If I get an error like this, I get a replacement disc, and the problem is solved.
But this time, because the error is the same on two different discs, this suggests to me a faulty pressing or master?
What I'm curious about is whether Mike can tell me what these debug codes mean... was MakeMKV able to successfully work around the problem?
Is there any way to know the timecode of the file it was ripping where the offset issue occurred, so that I can check the rip at that particular time?
Debug log started at Mon Feb 13 05:32:22 2017 , written by MakeMKV v1.10.2 win(x86-release)
001005:0000 MakeMKV v1.10.2 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\User/MakeMKV_log.txt
DEBUG: Code 2147483648 at S(8ev{HX:=PjlUc*:121265315
DAFD=PAAAADAAAAEABDQEEAQEBAQ==
DCE=3b0qGWN7+oqyIxuUm5fn7OXPeYPS8+mK6w3phSZVKjSA6ZtuCj4WRqeiPPosNowuNuMuz0xzK+grLoD1aqdB7xRm92htjRRcj5HWZwcL1VYvn3sihQq1f2Ob22tmFM/VU6yq87bGAHNbdqkjAqsfwT1tl6axDmGeJA==
DISCID=0B645FC2FC235E4FFFEB3C190BAA71663C3769AD
003307:0000 File 01002.mpls was added as title #0
003307:0000 File 01003.mpls was added as title #1
003307:0000 File 01004.mpls was added as title #2
003307:0000 File 01005.mpls was added as title #3
003307:0000 File 01006.mpls was added as title #4
003307:0000 File 00000.m2ts was added as title #5
003307:0000 File 00001.m2ts was added as title #6
003307:0000 File 00002.m2ts was added as title #7
003307:0000 File 00003.m2ts was added as title #8
003307:0000 File 00004.m2ts was added as title #9
003309:0000 Title 00005.m2ts is equal to title 01002.mpls and was skipped
003309:0000 Title 00006.m2ts is equal to title 01003.mpls and was skipped
003309:0000 Title 00007.m2ts is equal to title 01004.mpls and was skipped
003309:0000 Title 00008.m2ts is equal to title 01005.mpls and was skipped
003307:0000 File 00009.m2ts was added as title #10
003025:0000 Title #00010.m2ts has length of 0 seconds which is less than minimum title length of 1 seconds and was therefore skipped
003309:0000 Title 00011.m2ts is equal to title 01006.mpls and was skipped
005014:0000 Saving 1 titles into directory C:/Video
004004:0000 The source file '<Unknown>' is corrupt or invalid at offset 8177307648, attempting to work around
001003:0020 DEBUG: Code 1 at ^wIIOv}a4S*bT^BRGJK:121263107
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Mon Feb 13 05:46:02 2017
Using: ASUS BW-16D1HT 3.00
ndjamena
Re: seaQuest Season 1 German Blu-ray Release - Disc 2
#2 Post by ndjamena » Fri Feb 17, 2017 9:42 am
From my experience '<unknown>' file errors mean nothing and can be happily ignored.
I've have at least two DVDs that trip it. I have two copies of one of them and they both cause it at the same place, so it's definitely something to do with the way the discs are authored.
I contacted Mike about the first one I found but other than noting it was interesting he didn't do anything about it.
I have the Australian release of SQ1.
I'll rip it now and see if it does the same thing.
preserve
#3 Post by preserve » Fri Feb 17, 2017 9:44 am
Thanks for the info about your experience with this type of problem! Still hoping to learn more about it.
I have the Australian release as well - it doesn't have this problem.
The Australian release and the German release are different, that's why I bought them both :)
ndjamena
#4 Post by ndjamena » Fri Feb 17, 2017 9:49 am
I'm annoyed.
I got the Australian release of Quantum Leap S1 as well... then they didn't release any other season... THEN the complete series was released in America and now the AU release is just a waste of money.
And they haven't released any other seasons of SQ... and I'm keeping an eye on Amazon... and...
preserve
#5 Post by preserve » Fri Feb 17, 2017 9:55 am
Yeah, I bought the Australia of SQ1 first, and then they stopped.
Then Germany did SQ1 and SQ2, and SQ3 is coming out next week, I already ordered it :)
Plus the German release has nicer packaging.
I'm just happy it was released, I would have never, ever imagined that this show would be on Blu-ray. It gives me hope for other shows.
ndjamena
#6 Post by ndjamena » Fri Feb 17, 2017 10:10 am
Oh, I guess I should keep an eye on Amazon.de instead.
I keep away mostly because of a burning desire to get Eureka on Blu Ray and not having the money to spare.
I bought Season 2 of Transporter from .de only to find it had burnt in forced subtitles :(
preserve
#7 Post by preserve » Sat Feb 18, 2017 10:27 pm
Anyone?
Woodstock, do you have any knowledge about what the "<Unknown>" part means?
Should I submit this to the support email?
It would be awesome if MakeMKV could give the timecode when this occurs, just like it gives the timecode for AV sync issues encountered during ripping.
#8 Post by Woodstock » Sun Feb 19, 2017 2:08 am
No, I've got no insight into the "<unknown>"... At least in this particular instance.
Sometimes I can know the unknowable, but this is not one of them. :)
ndjamena
#9 Post by ndjamena » Sun Feb 19, 2017 12:53 pm
[Is this a problem?]
The source file '<Unknown>' is corrupt or invalid at offset 1119137792, attempting to work around
The source file '<Unknown>' is corrupt or invalid at offset 1071120384, attempting to work around
The source file '<Unknown>' is corrupt or invalid at offset 1152202752, attempting to work around
The source file '<Unknown>' is corrupt or invalid at offset 1154123776, attempting to work around
The source file '<Unknown>' is corrupt or invalid at offset 1194602496, attempting to work around
It happens at the end of each title on Vol 4 of TMNT 2012. It just looks odd.
> looks odd.
Usually no, it should be harmless. The "<unknown>" part looks odd though...
Thank you,
MakeMKV support
Maybe you can badger him more about it.
It also happens on Doctor Who: The Gunfighters (I think)... because my script kept rejecting the disc without being coded to output the full debug information I made the mistake of buying a second copy, which of course had the same problem. It was only then I took a better look at what was happening, realised what was going on and modified the script to ignore '<unknown>' file errors.
-edit- I sent that on the 19th of September 2014.
preserve
#10 Post by preserve » Tue Feb 28, 2017 9:12 pm
I submitted this with all the required files, and Mike sent me a reply with information on this issue - thanks Mike! Problem solved! :)
This is a disc mastering error. From practical side it is nothing - the
error is in the subtitle stream, so you have lost a single subtitle
frame. That was a forced subtitle frame, so you've got the error twice.
From error reporting part, yes, this is the bug. It is a first time we
see this error in practice - so next versions should report more sane
error messages in cases like this. Thanks!
