Ripped the disk with no errors, using 1.10.4 on Win 10.
When opening in MPC-HC x64 (latest stable build - 1.7.10), doesn't play and just hangs at 0:00:00 (i.e. no time progression).
Any ideas to fix?
Debug Log ...
Debug log started at Fri Feb 17 00:32:06 2017 , written by MakeMKV v1.10.4 win(x64-release)
001005:0000 MakeMKV v1.10.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Steven/MakeMKV_log.txt
DEBUG: Code 2147483648 at I.?+S<cUg )a\=/2:121265315
DAFD=PAAAADAAAAEABDQkEGAACAQ==
DCE=G2wMI7C0fujIDkmTtY2V36775PujLRJj2BOshOW1mRRUMjxd2a4xcXQrUrsOO3wNhA1L+VVCTVMiDoJJel9Mc/8pJxt0XEmOTxk4Z8uToXmjtCrA26xNaj3lKE7g3/rEishhSL0XQwnWCUm9dCmTSo8wAr0/p+NBDQ==
DISCID=F14390C72C27279BF076571B305CFD11171D2F3D
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00020.mpls was added as title #1
003307:0000 File 00250.m2ts was added as title #2
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01066.m2ts was added as title #3
003307:0000 File 01067.m2ts was added as title #4
003307:0000 File 01068.m2ts was added as title #5
003307:0000 File 01069.m2ts was added as title #6
003307:0000 File 01070.m2ts was added as title #7
005014:0000 Saving 1 titles into directory J:/Movies/Jack Reacher Never Go Back (2016)
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Fri Feb 17 01:03:57 2017
Status after ripping ...
1 titles saved
MPC details ...
MPC-HC (64-bit)
Build information:
Version: 1.7.10 (d911f14)
Compiler: MSVC 2013 Update 5
Build date: Nov 14 2015 18:25:24
LAV Filters:
LAV Splitter: 0.66.0.0
LAV Video: 0.66.0.0
LAV Audio: 0.66.0.0
FFmpeg compiler: MinGW-w64 GCC 4.9.2
Operating system:
Name: Windows NT 10.0 (build 14393)
Version: 10.0 (64-bit)
Hardware:
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
GPU: AMD Radeon HD 5570 (driver version: 8.17.10.1404)
MPC-HC x64 wont play ripped BD Jack Reacher - Never Go Back
Dingo69
Re: MPC-HC x64 wont play ripped BD Jack Reacher - Never Go B
First suggestion would be to try playing the file with another player. While it has its flaws, VLC from videolan.org seems to be able to at least play every MakeMKV-generated file I've thrown at it. It doesn't like h265 video on my system, but Blurays do not use that.
If VLC also can't play it, then there is likely something wrong with the MKV file. If VLC does play it, though, the suspicion falls to the MPC software.
Dingo69
Thanks for the tip.
It played the video in VLC, but the audio kept cutting in and out.
Maybe it's a crappy disc? I'll try cleaning it and re-ripp.
Dingo69
Cleaned the disc with the same result. I'll presume the disc is damaged and try a different one.
Thanks for the help.
ndjamena
It's not the physical disc, if MakeMKV was having problems reading from it then it would say so. Plus AACS provides hashes for the m2ts files... if the disc was dirty there's no way it could slip past MakeMKV.
Extract all the tracks using EAC3To, then remux them all using MKVMerge. See if that helps.
Or try re-encoding the audio, either upon ripping with MakeMKV or after using EAC3To.
Dingo69
Ok. Thanks. I will give that a go.ndjamena wrote:It's not the physical disc, if MakeMKV was having problems reading from it then it would say so. Plus AACS provides hashes for the m2ts files... if the disc was dirty there's no way it could slip past MakeMKV.
Dingo69
This was a complicated issue. It seems there is an AC3 track embedded in the TrueHD audio track, similar to what was described here ... https://forum.doom9.org/showthread.php? ... ost1425368
Maybe that was the cause of the audio cutting in & out when using MakeMKV to create an MKV from the BD?
Anyways ... so I used AnotherEAC3toGUI to isolate the TrueHD track and saved it as a FLAC.
Then, using MKVToolNix GUI I multiplexed the video, subtitles and audio into an MKV.
Plays without error now in VLC.
