How do I install a newly purchased MAKEMKV Key on Ubuntu ?
wtdedula
Post by wtdedula »
Hello All;
I am running the latest version of MAKEMKV on Ubuntu. I just purchased a license key but I can't see any way to install it. Can anyone tell me how ?
I have run MAKEMKV before and recall that I never had a problem installing a beta key but I don't recall what I did to install it.
Thanks.
Tim
yorgo
Re: How do I install a newly purchased MAKEMKV Key on Ubuntu
Post by yorgo »
I assume the Ubuntu version works identically to Windows. If not, please ignore.
Copy the multidigit key you received via email after purchasing. Copy only the exact characters; don't include any extra spaces, etc.
Start MakeMKV. At the top, look for the Help tab, select it, go to Register. A dialog box will appear. Paste the key, the press Okay. Restart MakeMKV, you should be all set. Let us know how it goes.
