Hacksaw Ridge
angelgraves13
Hacksaw Ridge
Post by angelgraves13 » Sun Feb 12, 2017 9:16 am
Anyone know the correct playlist?
hvnphoto
Re: Hacksaw Ridge
Post by hvnphoto » Tue Feb 14, 2017 5:29 am
Retail Version
Title information
Source file name: 00001.mpls
Duration: 2:19:19
Chapters count: 16
Segment count: 20
Segment map: 509,513,502,514,520,517,508,505,515,501,506,503,516,519,512,504,507,518,510,511
File name: Hacksaw_Ridge_t00.mkv
Might be 00411.mpls for another version. The segment map is correct.
CIR Engineering
Re: Hacksaw Ridge
Post by CIR Engineering » Wed Feb 15, 2017 9:06 pm
hvnphoto wrote:Retail Version
Title information
Duration: 2:19:19
Chapters count: 16
Segment count: 20
Might be 00441.mpls for another version. The segment map is correct.
Thank you for posting the segment map. I have been meaning to sign up to this forum for a while, but your post was so helpful that I finally did it.
Kind regards,
craigr
CIR Engineering
Re: Hacksaw Ridge
Post by CIR Engineering » Wed Feb 15, 2017 9:43 pm
Also looks like playlists 00001.mpls and 00377.mpls matches on mine.
non
Crtguy
Re: Hacksaw Ridge
Post by Crtguy » Wed Feb 15, 2017 9:50 pm
? NF playlist
Cornstick
Re: Hacksaw Ridge
Post by Cornstick » Fri Feb 17, 2017 3:58 am
377 is what I get. US Retail version.
Paratel
Re: Hacksaw Ridge
Post by Paratel » Tue Feb 21, 2017 2:19 pm
Anyone have an idea for Hacksaw Ridge Redbox Version?
czmartinez
Re: Hacksaw Ridge
Post by czmartinez » Tue Feb 21, 2017 3:51 pm
Any clue on the Redbox Version?
mito118
Re: Hacksaw Ridge
Post by mito118 » Tue Feb 21, 2017 5:22 pm
czmartinez wrote:Any clue on the Redbox Version?
AnyDVD says that it is playlist 760.
sweakley2012
Re: Hacksaw Ridge
Post by sweakley2012 » Tue Feb 21, 2017 10:07 pm
Still looking for playlist for redbox Blu-ray version. Anyone solved this one yet?
theonegod
Re: Hacksaw Ridge
Post by theonegod » Tue Feb 21, 2017 10:08 pm
I am a little confused why you would ask. Not trying to be negative, but at least for me, MakeMKV tells me which one is the feature film in the most current version with this title.
claven311
Re: Hacksaw Ridge
Post by claven311 » Tue Feb 21, 2017 10:12 pm
There are about 100+ "feature" files, all with varying segment maps. None of the previous posts list information consistent with what is on the redbox version. I'd post the correct answer myself if I knew how to find it.
-Cliff
theonegod
Re: Hacksaw Ridge
Post by theonegod » Tue Feb 21, 2017 10:16 pm
In my copy of MakeMKV it lists all of the versions yes, but at the top it shows the ones it has identified as the feature as well as the trailers and other things. In this case yes, the Redbox version was 760 as the other poster stated. But MakeMKV showed me this without me having to do anything.
Paratel
Re: Hacksaw Ridge
Post by Paratel » Tue Feb 21, 2017 10:24 pm
theonegod wrote:In my copy of MakeMKV it lists all of the versions yes, but at the top it shows the ones it has identified as the feature as well as the trailers and other things. In this case yes, the Redbox version was 760 as the other poster stated. But MakeMKV showed me this without me having to do anything.
760 does not work even though it says main feature.
theonegod
Re: Hacksaw Ridge
Post by theonegod » Tue Feb 21, 2017 10:56 pm
Based on what? Seems to work for me.
