2 movies on 1 bluray disc - how to rip & get both files?
Mr Friz
#1 Post by Mr Friz » Tue Feb 14, 2017 12:12 am
I cannot seem to successfully rip a BR with 2 or more movies on it and get a file for each movie. It only pulls 1 file.
Couldn't find assistance in previous forums. Please help...
Thanks,
Patrick
Re: 2 movies on 1 bluray disc - how to rip & get both files?
#2 Post by Woodstock » Tue Feb 14, 2017 6:31 am
Without seeing your debug log, the "best guess" I can come up with is that you have the minimum time set to a level too high for MakeMKV to think you want the second movie, because it normally selects ALL titles that meet or exceed your minimum time.
If you want more than that, I'd need to see your debug log (link in my signature tells you how to turn it on and find it).
Mr Friz
#3 Post by Mr Friz » Tue Feb 14, 2017 9:16 am
Here is the text comments from the debug file.
Debug log started at Tue Feb 14 07:56:13 2017 , written by MakeMKV v1.10.4 win(x64-release)
001005:0000 MakeMKV v1.10.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\pfris/MakeMKV_log.txt
005072:0000 Backing up disc into folder "F:/Blu Ray Movies/GAMERA ULTIMATE COLLECTION V1"
DEBUG: Code 2147483648 at I.?+S<cUg )a\=/2:121265315
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=BWAQwhpQAeq0LRZHO6PAYVyHazRLrIJbuNzqyKPBhW3YaTx3j8lLP38B64+J0zVMIkvV13uFN3ZRMLYhQC2T2X5qoCwBDC1WNXHmSbjaMr1Dhm7wAgQ7Iae6QJwSQ8rvAG7HKigiOd65Oeu95I0rMeP/jVr8SH2wCQ==
DCE=jNQuzrJzBiTcgbLq2UfKFGtBgbD1iYxcXm/+EP0wN40daCpVhotJjj+iYClL1bhk0TCEYkMFN3gwSSd5jZFxx1GgWOcl3vZxLU594gxGt9WAMRfveQ6COgUBIkKYQIBKGCdxpp57HBckGWXVS0aplAExMmGAMKIngA==
001003:0020 DEBUG: Code 233 at R/SF8+xcfyc90nYhOnPOOauo:0
001003:0020 DEBUG: Code 233 at Qsd8qVEPm2rj/zObgREIVBPI:0
001003:0020 DEBUG: Code 233 at tcyVNLozN/fFsaxu7a1lhw//:0
001003:0020 DEBUG: Code 233 at A7xKkMcS4eJjGQj3IOOsxcSu:0
001003:0020 DEBUG: Code 233 at 0oPUVtPgXSFnj21Jb4etkAFj:0
001003:0020 DEBUG: Code 233 at LxrceM7lpXcfMyqPKQhQzuH/:0
001003:0020 DEBUG: Code 233 at iZKAJzgdzYH/ZGUgUy8oCbGP:0
001003:0020 DEBUG: Code 233 at JvFSrFzuQEoAAyd7w1BAt3of:0
001003:0020 DEBUG: Code 233 at kOE5nnAA6SS/KHm9nxvCFODh:0
001003:0020 DEBUG: Code 233 at NpvvnobrghWQPqmc4uf0mLBw:0
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Tue Feb 14 08:54:51 2017
This disc is the Gamera Movie Collection - Vol 1. There are 4 individual movies on this single BR disc.
Thanks for your help. I look forward to your reply. Thanks again...
#4 Post by Woodstock » Tue Feb 14, 2017 2:18 pm
OK, you did a backup, which means the entire file structure was copied to your drive... So, now your PLAYER has to understand how to navigate to them. If it limits your view to the "main feature", it is hiding the rest from you.
Try this: Load the disk in the drive. Click on the big button that looks like a disk (it "spins" while the disk is loading).
How many titles are shown? What are their sizes?
Mr Friz
#5 Post by Mr Friz » Tue Feb 14, 2017 3:44 pm
There are 4 titles, all with the same name but different sizes: 12.6, 9.9, 10.9, & 10.2GB. The destination folder is 43.9GB, which is roughly the size of most of the other single movie discs I have already ripped.
After ripping I'm using HandBrake to compress it to a mp4.
I'm super new to all of this and sincerely appreciate your help
#6 Post by Woodstock » Wed Feb 15, 2017 1:24 am
"All the same name" is because the files do not have movie names on them; MakeMKV tries to make up for that by using the disk name, which works for many titles, but not a "4-in-1 movie pack". You can edit the name before ripping, and if you turn on Expert mode (Preferences->General), you can even change the name of the file before it is written to disk.
In the situation you have, you can probably get which title is which movie by comparing the running time MakeMKV lists against what it says on the box.
As for being "super new", all of us started out that way. The way to learn is to play with it. Treat it as an adventure game. You are given tools (disks, software). You have a goal (make file that can be played in the way you want it). The number of "lives" you get depends entirely on the time you have to play.
Mr Friz
#7 Post by Mr Friz » Wed Feb 15, 2017 2:25 am
Thanks for the help and encouragement!!!
