Free State of Jones - Read Error
Kappabear
Post by Kappabear »
I'm trying to convert the movie "Free State of Jones", and have run into the same error, no matter what I try. I've even washed the disc, and that hasn't helped. There is a tiny little chip on the edge of the DVD that could be causing this error. However, I am able to play the movie all the way through on my computer and DVD player with no issues.
I'm not sure if this is the correct error log or not. If there's another that I should attach, please let me know.
Debug log started at Sat Feb 11 01:56:53 2017 , written by MakeMKV v1.10.4 darwin(x86-release)
001005:0000 MakeMKV v1.10.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/ME/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02d" opened in OS access mode.
001012:0000 Open DVD manually : "1:1-20"
003028:0000 Title #1 was added (21 cell(s), 2:19:40)
005014:0000 Saving 1 titles into directory /Users/ME/Movies/FREE_STATE_OF_JONES
001003:0020 DEBUG: Code 0 at :D>riV%#*)]aaM67X:121262026
001003:0020 DEBUG: Code 1073741829 at "|H?2N %8cDnU=J7:29393953
001003:0020 DEBUG: Code 100864261 at R!uHv<o_rR:g@!5):121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '3910938624'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '3910938624'
DEBUG: Code 1073741829 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 1073741829 at RT>0\^Fe?{:c[sc./F:121262969
DEBUG: Code 100864261 at RT>0\^Fe?{:c[sc./F:213130904
001003:0020 DEBUG: Code 100864261 at RT>0\^Fe?{:c[sc./F:121262969
001003:0020 DEBUG: Code 0 at 3(WCQn/XbnJ/7(ZK_syF:213131387
001003:0020 DEBUG: Code 0 at +nXcji4[F[$WfLu]Dwi:213129938
001003:0020 DEBUG: Code 0 at 3(WCQn/XbnJ/7(ZK_syF:29394459
001003:0020 DEBUG: Code 1909638 at 3(WCQn/XbnJ/7(ZK_syF:121261497
001003:0020 DEBUG: Code 0 at ut37.2!aXpNS(t(`DD<ET:213135297
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 0 to file /Users/ME/Movies/FREE_STATE_OF_JONES/title00.mkv
002023:0000 Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=11 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 6 unclassified errors
error=0x40000005 count=6 name=Posix error - Input/output error
005004:0080 0 titles saved, 1 failed
Re: Free State of Jones - Read Error
These types of errors are most likely due to dirty disks, although there can be other reasons. The fact that the error doesn't move around means that it is a specific area on the disk that is not readable, as opposed to any speed-related problems.
Advice: Clean the disk with a damp soft cotton or microfiber cloth, and try again.
