Dvd Menu command does not appear
ecofugal
Post by ecofugal »
I have an Imac running El Capitan 10.11 and recently purchased a external Blu-Ray player.
I installed MakeMKV and got VLC (Version 2.2.4) playing Blu-Rays now.
Only one small problem. The movie menu screen does not appear and I can’t access it at all. The movie begins instantly.
The Dvd Menu command doesn't appear in VLC>Playback>Title>
When I play DVD movies its works fine and I can the access the dvd menu.
Its seems to only happen with my Blu-Ray discs.
Any idea what I am doing wrong?
Many thanks
Re: Dvd Menu command does not appear
Best guess is that VLC assumes you want to play the main feature, and goes directly to it.
You might check VLC's preferences and see if there is a setting to use the menus.
