How does MakeMKV separate DTS core from DTS HD-MA ?
abel413
#1 Post by abel413 » Sat Dec 17, 2016 8:03 pm
When I rip a BluRay, MakeMKV offers both DTS-HD MA & DTS. Then it is possible to select both and to have both audio at the end.
If I extract full BluRay manually then try to remux m2ts corresponding to the movie on MKVToolNix only DTS-HD MA appears. Then I wonder how MakeMKV manages to separate both audio. I would like to know how to do that manually.
preserve
Re: How does MakeMKV separate DTS core from DTS HD-MA ?
#2 Post by preserve » Tue Jan 03, 2017 11:35 pm
Have a look at this, maybe this will help you?
https://github.com/mbunkus/mkvtoolnix/issues/1107
Using: ASUS BW-16D1HT 3.00
necrosis
#3 Post by necrosis » Thu Feb 02, 2017 2:30 am
It is pointless to rip both. Only grab the DTS-MA.
If what you play it back on only supports DTS it will still play fine.
yorgo
#4 Post by yorgo » Thu Feb 02, 2017 12:19 pm
necrosis wrote:It is pointless to rip both. Only grab the DTS-MA.
I respectfully disagree. I'd suggest each person needs to check if the higher resolution track can play on their media player, playback software, AV receiver/processor, or combination of these. I've had instances in the past with certain player/receiver combinations where the hi-rez DTS-MA track would not play and I had to revert to standard DTS. My standard is to save both high resolution and core tracks but YMMV.
abel413
#5 Post by abel413 » Sat Feb 04, 2017 7:02 am
In my case, my BluRay player don't play DTS HD MA so I can only play DTS.
