CyberLink MediaEspresso
crzcnc_17
Trying to use CyberLink MediaEspresso to encode my movies but it says the audio isn't supported has anyone tried this program and if so how do I save the audio track as a different format?
Re: CyberLink MediaEspresso
Wow... had not heard of this program before, but a google search for it comes up with a wide variety of links on the first page, starting with CyberLink's product page, and ending with "How do I remove this malware?"
Based on their limitations page:
Do you have Expert mode turned on (Preferences->General) in MakeMKV to allow you to use profiles?
I'd say there aren't many audio formats that it DOES support. You may need some other tool prior to it to convert the audio. And if you need another tool, you might as well use something that supports the full conversion. although ripping with MakeMKV's FLAC profile might do the job.WAV, FLAC, WMA, MP3, M4A (AAC / ALAC), Videos with Dolby Digital 5.1 audio soundtracks
crzcnc_17
Yeah figured that flac out last night!! Just trying to find something that can use intels quick sync. Thanks for your help
On Windows, handbrake (handbrake.fr) can use QSV. If you're not concerned about quality or size, that is.
The intention of QSV is for things like a transcoding server - you have video in one format, and it will reformat it on the fly for clients, according to what they support. It is VERY good at that.
What it isn't that good at is making files with high quality and small sizes. When I was testing it, the speed on converting BD video was 10 times what the software encoder x264 could do (300 frames per second vs. 20-30 fps), but the resultant file was 10% or more larger, and there were more visual artifacts. I gave up the speed to get the quality.
