Question about Cinavia
boe_d
Post by boe_d » Sun Jan 15, 2017 12:10 am
I converted inferno for an MKV from a BD. I have a new Oppo 203 and it popped up with a cinavia warning. I'm not complaining about the 203 or makemkv, I'm just trying to get up to speed. The older oppo 103 does not have this issue when streaming the same MKV file. Is this something that is unavoidable with some BD conversions or is there something I can do?
Re: Question about Cinavia
Post by Woodstock » Sun Jan 15, 2017 2:08 am
With MakeMKV, there's nothing you can do, because it is going to faithfully copy the audio from the source to the MKV file. It's the audio itself that is the problem.
I see you've found the main Cinavia topic here, with pretty much everything there is to know, from the MakeMKV side.
MrVideo
Post by MrVideo » Mon Jan 16, 2017 4:36 am
boe_d wrote:The older oppo 103 does not have this issue when streaming the same MKV file.
Players built before Feb 2013 did not have to detect Cinavia.
TheShoe
Post by TheShoe » Sun Jan 29, 2017 4:55 pm
Here's the deal with Oppo players:
The BDP-103/105 only enforce Cinavia via disc playback.
The UDP-203/205 enforce Cinavia via:
- disc playback
- attached USB storage in any container
- DLNA playback in any container
- network playback in any container
However - if you have an external HTPC that decodes the MKV and feeds the audio/video to the Oppo's HDMI input, Cinavia is NOT enforced.
