Several DVD's lately have Not created any Audio
MartinElk
Post by MartinElk » Sat Jan 28, 2017 9:46 pm
3 or so DVD's I've processed through MakeMKV, [MakeMKV v1.10.4 win(x64-release)] do NOT create any Audio component, even though it is definitely there on the DVD.
I've tried using earlier versions to see if it is just the latest version that is the problem, but they are doing the same thing. I have purchased the software license, so I can try that.
I've attached the log file from the last session.
If you need anything else to debug this, please let me know.
MakeMKV v1.10.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Martin.Williams/MakeMKV_log.txt
Opening files on harddrive at P:/Torrents/Spa Night (with german subs) Untouched DVD PAL
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Title #1 has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 was added (2 cell(s), 0:02:11)
Title #8 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (13 cell(s), 1:32:27)
Saving 2 titles into directory P:/Video/SPA_NIGHT_DVD using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/aac-stereo.mmcp.xml'
2 titles saved
Re: Several DVD's lately have Not created any Audio
Post by Woodstock » Sat Jan 28, 2017 10:34 pm
Is your aac-stereo.mmcp.xml file the original, stock file?
What happens if you use the default profile?
