Cars DVD (CRZ0NNW8)
immortel
Cars DVD (CRZ0NNW8)
Post by immortel »
MakeMKV find all the short movies that comes with the DVD but do not find the main movie.
I attach are the logs.
Can you help me?
Re: Cars DVD (CRZ0NNW8)
As a Disney DVD or Bluray, there should be either 2 or 3 "copies" of the movie on the disk, one each in English, Spanish, and French. And MakeMKV found all of them when I ripped it 5 years ago. The only difference was the titles/credits.
Post the log of the scan as part of your message. Copy the log to the clipboard, start your reply, then click the "Code" button above the message box. You can then paste the log in between the code tags that will appear.
immortel
Post by immortel »
Here's the logs
Debug log started at Thu Jan 26 16:33:39 2017 , written by MakeMKV v1.10.4 linux(x64-release)
001005:0000 MakeMKV v1.10.4 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/dany/MakeMKV_log.txt
003025:0000 Title #6 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=6 pgcn=2 hash=E66145B9C0B2F69D
003019:0000 Cells 4-end were skipped due to cell commands (structure protection?)
003028:0000 Title #14 was added (3 cell(s), 0:04:16)
Title skip vts=7 pgcn=1 hash=980FCD1B4B927FBB
003025:0000 Title #16 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #17 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #18 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #19 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 86-end were skipped due to cell commands (structure protection?)
003024:1000 Complex multiplex encountered - 17 cells and 860 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
001003:0020 DEBUG: Code 100864261 at SMR_fJyLnov|QU2|:121269731
001003:0020 DEBUG: Code 1877288 at UKX![aLM(d"9ahl2:121263383
001003:0020 DEBUG: Code 0 at xX8oWM~(/Z3SGKq6o6:121273457
001003:0020 DEBUG: Code 0 at xX8oWM~(/Z3SGKq6o6:29406879
003015:0000 Title #23 (1:56:23) was skipped due to navigation error
Title skip vts=10 pgcn=1 hash=4BA2B9724E5355B7
003025:0000 Title #26 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #27 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #29 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #35 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #36 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 9-end were skipped due to cell commands (structure protection?)
003028:0000 Title #37 was added (8 cell(s), 0:15:59)
Title skip vts=12 pgcn=1 hash=21B53CA9F0915730
003028:0000 Title #38 was added (3 cell(s), 0:07:07)
Title skip vts=13 pgcn=1 hash=67548FC07BC96E66
003025:0000 Title #39 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #40 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #41 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003028:0000 Title #42 was added (2 cell(s), 0:04:31)
Title skip vts=15 pgcn=1 hash=8E369DDAF58B5F09
Title skip vts=16 pgcn=3 hash=0B8C14CE27F7CD1F
003025:0000 Title #44/2 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #44/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #46 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #48/2 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #51 was added (2 cell(s), 0:03:50)
Title skip vts=20 pgcn=1 hash=9859BBBF9E195399
003025:0000 Title #52 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #53 was added (2 cell(s), 0:03:14)
Title skip vts=20 pgcn=3 hash=B2353D3EDB4EBC61
003025:0000 Title #54 has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #55 was added (8 cell(s), 0:10:29)
Title skip vts=20 pgcn=5 hash=8E9BDA959866E7FE
003025:0000 Title #59 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 0 at ]JQh)!&BY!wvez``z{uUg0V:213130122
001003:0020 DEBUG: Code 233 at xnDz2Fm2gTys1u+2/NyW/J/G:0
It looks like there are some problems reading the disk when MakeMKV tries to find all the parts of this file. The debug information says it got unexpected data from the drive. Mike has said that some drives, when they can "almost" read a sector, will return what they can, rather than report a read error.
I'd go with cleaning the disk first, and trying the rip again.
immortel
Post by immortel »
Oh! Too dirty or too many scratches...
Not impossible. Few kids played with it.
Thanks for the information. I will try clean it up or find someone else who has the DVD.
