Anime DVD Issues
darksaber2001
Anime DVD Issues
Post by darksaber2001 »
2 Series so far, same problem. Makemkv 1.10.4 64bit scans the discs fine, proceeds through a fair portion of the processing, and then crashes with the error "Fatal error occurred, program will not exit". In both cases the titles have 2 angles (Don't know if that matters or not). So far, Dvdfab doesnt have a problem with them, so I'm assuming it's not a disc issue.
Fullmetal Alchemist (Original, not Brotherhood)
Disc 1 and 2 present the same issue. Stopped with the 2nd disc assuming others will follow suit. Posting logs for disc 2.
MakeMKV log
Debug log started at Wed Jan 25 14:57:45 2017 , written by MakeMKV v1.10.4 win(x64-release)
001005:0000 MakeMKV v1.10.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\wflagge.USADIR/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003025:0000 Title #1 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 24 cells and 5542 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (49 cell(s), 1:35:20)
003024:1000 Complex multiplex encountered - 24 cells and 5548 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003040:0000 Angle #2 was added for title #2
003025:0000 Title #3 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3/1 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/1 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/2 has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #4/3 was added (1 cell(s), 0:02:07)
003025:0000 Title #4/4 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5/1 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5/2 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5/3 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #7 was added (7 cell(s), 0:04:28)
003025:0000 Title #8 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=1 pgcn=18 hash=A50102FA98007431
003034:0000 Audio stream #1 looks empty and was skipped
003034:0000 Audio stream #2 looks empty and was skipped
005014:0000 Saving 2 titles into directory E:/Movies
001003:0020 DEBUG: Code 0 at [?)jw:x7>UE\('I|q:121262026
AV sync issues in E:/Movies/title00.mkv
AV sync in 1 at 0:47:48.384 (48.233ms) : audio gap - 1.507 missing frame(s)
001001:0020 DBG ASSERT: (eK.fvE9i3e[Z0&:~n3C{M/?z6zW~&QMK at jlgSI!4!L`:z0m4ty#]:121267707
Windows Error log
Consent=1
UploadTime=131298274660646833
ReportIdentifier=0a51f6a1-e309-11e6-9c27-c759b9931f45
IntegratorReportIdentifier=e6df5af1-1ce7-4b4a-86d3-b8221130f542
NsAppName=makemkvcon64.exe
AppSessionGuid=00003600-0001-0020-1117-c4eb1377d201
TargetAppId=W:0006c3f343a71dae5543e4c125409d57244a0000ffff!000094cc663fe817b6c0d8549ce67fab5b9a5652b834!makemkvcon64.exe
TargetAppVer=2016//12//25:16:25:13!4de1fd!makemkvcon64.exe
BootId=4294967295
Response.BucketId=ae1cc1d9db5fa1f54944883ad3ac40f6
Response.BucketTable=4
Response.LegacyBucketId=120671878072
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=makemkvcon64.exe
Sig[1].Name=Application Version
Sig[1].Value=0.0.0.0
Sig[2].Name=Application Timestamp
Sig[2].Value=585ff2e9
Sig[3].Name=Fault Module Name
Sig[3].Value=makemkvcon64.exe
Sig[4].Name=Fault Module Version
Sig[4].Value=0.0.0.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=585ff2e9
Sig[6].Name=Exception Code
Sig[6].Value=c0000005
Sig[7].Name=Exception Offset
Sig[7].Value=000000000022730a
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=10.0.14393.2.0.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=61b0
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=61b03ad54f6f14622dae004219497873
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=e377
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=e3777e546c5eb6c1ab5bd373576eb622
UI[2]=C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
UI[3]=makemkvcon64.exe has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\WINDOWS\System32\KERNEL32.DLL
LoadedModule[3]=C:\WINDOWS\System32\KERNELBASE.dll
LoadedModule[4]=C:\WINDOWS\System32\ADVAPI32.dll
LoadedModule[5]=C:\WINDOWS\System32\msvcrt.dll
LoadedModule[6]=C:\Program Files (x86)\MakeMKV\libdriveio64.dll
LoadedModule[7]=C:\Program Files (x86)\MakeMKV\libmakemkv64.dll
LoadedModule[8]=C:\WINDOWS\System32\sechost.dll
LoadedModule[9]=C:\WINDOWS\System32\RPCRT4.dll
LoadedModule[10]=C:\WINDOWS\SYSTEM32\msvcp60.dll
LoadedModule[11]=C:\WINDOWS\System32\USER32.dll
LoadedModule[12]=C:\WINDOWS\System32\win32u.dll
LoadedModule[13]=C:\WINDOWS\System32\GDI32.dll
LoadedModule[14]=C:\WINDOWS\System32\gdi32full.dll
LoadedModule[15]=C:\Program Files (x86)\MakeMKV\libffm64.dll
LoadedModule[16]=C:\Program Files (x86)\MakeMKV\libfdk64.dll
LoadedModule[17]=C:\WINDOWS\System32\IMM32.DLL
LoadedModule[18]=C:\WINDOWS\SYSTEM32\CRYPTBASE.DLL
LoadedModule[19]=C:\WINDOWS\System32\bcryptPrimitives.dll
LoadedModule[20]=C:\WINDOWS\SYSTEM32\WININET.DLL
LoadedModule[21]=C:\WINDOWS\SYSTEM32\iertutil.dll
LoadedModule[22]=C:\WINDOWS\System32\combase.dll
LoadedModule[23]=C:\WINDOWS\System32\ucrtbase.dll
LoadedModule[24]=C:\WINDOWS\System32\shcore.dll
LoadedModule[25]=C:\WINDOWS\SYSTEM32\SspiCli.dll
LoadedModule[26]=C:\WINDOWS\System32\windows.storage.dll
LoadedModule[27]=C:\WINDOWS\System32\powrprof.dll
LoadedModule[28]=C:\WINDOWS\System32\shlwapi.dll
LoadedModule[29]=C:\WINDOWS\System32\kernel.appcore.dll
LoadedModule[30]=C:\WINDOWS\System32\profapi.dll
LoadedModule[31]=C:\WINDOWS\System32\OLEAUT32.dll
LoadedModule[32]=C:\WINDOWS\System32\msvcp_win.dll
LoadedModule[33]=C:\WINDOWS\System32\WS2_32.dll
LoadedModule[34]=C:\WINDOWS\SYSTEM32\ondemandconnroutehelper.dll
LoadedModule[35]=C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
LoadedModule[36]=C:\WINDOWS\SYSTEM32\winhttp.dll
LoadedModule[37]=C:\WINDOWS\system32\mswsock.dll
LoadedModule[38]=C:\WINDOWS\System32\NSI.dll
LoadedModule[39]=C:\WINDOWS\SYSTEM32\WINNSI.DLL
LoadedModule[40]=C:\WINDOWS\SYSTEM32\DNSAPI.dll
LoadedModule[41]=C:\WINDOWS\SYSTEM32\urlmon.dll
LoadedModule[42]=C:\Program Files\Bonjour\mdnsNSP.dll
LoadedModule[43]=C:\Windows\System32\rasadhlp.dll
LoadedModule[44]=C:\WINDOWS\System32\fwpuclnt.dll
LoadedModule[45]=C:\WINDOWS\SYSTEM32\bcrypt.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppPath=C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=78950197D49084C5F8D7C06355D8269F
MetadataHash=1473272116
darksaber2001
Re: Anime DVD Issues
Full Metal Panic the 2nd Raid Disc 1
Crash occurs only when selecting angle 2 of video titles
MakeMKV Log
Debug log started at Wed Jan 25 15:15:00 2017 , written by MakeMKV v1.10.4 win(x64-release)
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003025:0000 Title #1 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/1 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/2 has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/3 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/4 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/5 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/6 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2/7 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 12 cells and 3952 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #3 was added (29 cell(s), 1:34:08)
003024:1000 Complex multiplex encountered - 12 cells and 3946 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003040:0000 Angle #2 was added for title #3
003024:1000 Complex multiplex encountered - 3 cells and 989 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #4 was added (7 cell(s), 0:23:30)
003024:1000 Complex multiplex encountered - 3 cells and 986 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003040:0000 Angle #2 was added for title #4
003028:0000 Title #5 was added (7 cell(s), 0:23:33)
003024:1000 Complex multiplex encountered - 3 cells and 988 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003040:0000 Angle #2 was added for title #5
003028:0000 Title #6 was added (7 cell(s), 0:23:33)
003040:0000 Angle #2 was added for title #6
003028:0000 Title #7 was added (7 cell(s), 0:23:31)
003040:0000 Angle #2 was added for title #7
003024:1000 Complex multiplex encountered - 1 cells and 246 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #8 was added (2 cell(s), 0:05:49)
003040:0000 Angle #2 was added for title #8
003025:0000 Title #9 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9/1 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9/2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #10 was added (3 cell(s), 0:02:37)
003028:0000 Title #11 was added (1 cell(s), 0:20:46)
003028:0000 Title #12 was added (1 cell(s), 0:25:58)
003028:0000 Title #13 was added (1 cell(s), 0:15:22)
003034:0000 Audio stream #4 looks empty and was skipped
003030:0000 Subtitle stream #3 is identical to stream #2 and was skipped
003030:0000 Subtitle stream #4 is identical to stream #2 and was skipped
005014:0000 Saving 5 titles into directory E:/Movies
004007:0010 AV synchronization issues were found in file 'E:/Movies/title03.mkv' (title #4)
004008:0010 AV sync issue in stream 1 at 0:00:00.002 with duration of 192ms : 6 early frame(s) dropped at start
DEBUG: Code 1 at lkW-02[s4_>^}J 4VATE:29398852
RH2=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
FS ID=V_MPEG2 C=1
TI=ZeNpjZICAt0+qrrMwMRAEDe1lYHUz0PjMONQnvAmGs5GNvwDkPGBkYAhlhtAGpQwML5mhalgwzWFmZHgAogHXQg+B
C_00000=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
004004:0000 The source file '<Unknown>' is corrupt or invalid at offset 70961152, attempting to work around
This may be the Windows error log. Wasn't paying enough attention to the time.
Version=1
EventType=APPCRASH
EventTime=131298316733023436
ReportType=2
Consent=1
UploadTime=131298316734487475
ReportIdentifier=d6171089-e312-11e6-9c27-c759b9931f45
IntegratorReportIdentifier=e8ac0dcc-2463-4b79-a9cd-898e4e920b3e
AppSessionGuid=00001018-0001-0020-be1a-09cc1d77d201
BootId=4294967295
Response.type=4
DynamicSig[24].Value=2dbd
DynamicSig[25].Value=2dbdb3a2092134a3f1e5f0bd8edf7f4c
LoadedModule[6]=C:\WINDOWS\System32\sechost.dll
LoadedModule[8]=C:\Program Files (x86)\MakeMKV\libdriveio64.dll
State[0].Value=1
ConsentKey=APPCRASH
NsPartner=windows
NsGroup=windows8
MetadataHash=1887325887
Send an email to Mike at support@makemkv.com with a link to this topic. I ripped this set almost 4 years ago without issue, and it did not cause problems back then.
dnevus
Post by dnevus »
i have found since the last update, the large quantity of Anime i have results in this same error. i have a few hundred left, and it seems most are plauged by the issue of getting all the way down to the last 1% before the crashes occur.
any idea how to get a prior version so we can at least get the them encoded for the time being?
Prior versions are found here: /download/old/
If, say, version 1.9.9 will rip a disk that 1.10.4 won't, then Mike needs to look into it. Just be aware that you might not be able to rip the latest BD titles with the older version.
dnevus
Post by dnevus »
10.2 definately could, as well as the prior ones. 10.4 is what crashes. i'l start sending up error logs. thanks!
Post by mike admin »
This is a confirmed bug. Unfortunately the cause is still unknown. Please send a testdump per instructions at /onlinehelp/testdump.html for any single title that causes the crash. Thanks!
