Correct Title to Rip Deepwater Horizon?
knot2bfound
Post by knot2bfound » Sun Jan 22, 2017 12:41 am
Been trying to rip Deepwater Horizon and even with java on my Mac I get hundreds of titles all about 29Gb per Make MKV. Which on is correct. I looked at the order of the segments in each one and none follow alpha numeric order.
Can anyone tell me which title to use for Make MKV?
Thanks for any help.
yorgo
Re: Correct Title to Rip Deepwater Horizon?
Post by yorgo » Sun Jan 22, 2017 2:48 am
Been discussed in another thread, recommend you check it out: https://www.makemkv.com/forum2/viewtopi ... =8&t=15594
knot2bfound
Post by knot2bfound » Sun Jan 22, 2017 3:41 am
Thanx... Found what I needed... Just couldn't believe that they tagged the one to use like they did.
