Been trying to rip Deepwater Horizon and even with java on my Mac I get hundreds of titles all about 29Gb per Make MKV. Which on is correct. I looked at the order of the segments in each one and none follow alpha numeric order.
Can anyone tell me which title to use for Make MKV?
Thanks for any help.
						Correct Title to Rip Deepwater Horizon?
Re: Correct Title to Rip Deepwater Horizon?
Been discussed in another thread, recommend you check it out:  https://www.makemkv.com/forum2/viewtopi ... =8&t=15594
									Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
				knot2bfound
Thanx... Found what I needed... Just couldn't believe that they tagged the one to use like they did.
