Finding Dory
steven83
Finding Dory
#1 Post by steven83 » Wed Jan 18, 2017 5:31 pm
I've tried to make a mkv of finding dory, the bd with german language (00801.mpls)
I got the same error with two different discs.
I was able to copy the hole content of the bd to the local sdd and got the same error when using the folder on the ssd
Die Quell-Datei '/BDMV/STREAM/00411.m2ts' ist defekt oder ungültig bei Offset 651589632. Es wird versucht, dies zu umgehen
Fehler 'Interner Fehler - Eingabeparameter ist falsch (904)' trat auf während des Auslesens von '<Unknown>' bei Offset '849659904'
Titel 5 in Datei /Users/xxxxxx/Filme/FINDING_DORY_2D/title05.mkv zu speichern schlug fehl
0 Titel wurden gesichert, 1 schlugen fehl
Any help would be welcome
Re: Finding Dory
#2 Post by Woodstock » Wed Jan 18, 2017 6:53 pm
I've never seen "Internal error (904)", so Mike will have to respond on this one.
However, you might try one of the older versions found here: /download/old/
If you get different results, please let us know.
steven83
Re: Finding Dory
#3 Post by steven83 » Thu Jan 19, 2017 6:34 am
Version 1.9.7 up to Version 1.10.0 does not gave a error but it takes forever. It's starts with the copy and after some seconds the read speed goes down to 0.0k/s
This old versions also detects some Audio tracks wrong, is telling that a "DDplus Sourround 7.1" is only "DDP Sourround 4.0"
steven83
Re: Finding Dory
#4 Post by steven83 » Fri Jan 20, 2017 11:31 am
Re: Finding Dory
#5 Post by Woodstock » Fri Jan 20, 2017 2:04 pm
Send Mike an email at support@makemkv.com with a link to this topic. That's the fastest way to get his attention, and we'll need it on this one.
moravec
Re: Finding Dory
#6 Post by moravec » Sat Jan 21, 2017 7:49 am
I have the same problem with this disc. Does it have a Special protection?
00411.m2ts play ok in VLC.
Regards
Christian
