Rambo 2008 not being correctly processed
kiszka6911
#1 Post by kiszka6911 » Mon Jan 16, 2017 5:49 pm
Rambo 2008 is not being correctly processed. Decrypting the movie and then using Handbrake to encode or using make MKV both had the same result. You get the special features put together as a movie. Looking at the mkv files the audio for most titles is coming in as two channel stereo. I played around with trying to put the correct titles together but couldn't make it work. Thanks!
kiszka6911
Re: Rambo 2008 not being correctly processed
#2 Post by kiszka6911 » Mon Jan 16, 2017 6:04 pm
I wanted to add I am processing this from an original blu-ray disc, region one that I own. Tried both my HTPC and my workstation at work. Both have LG drives. My workstation drive is 2016 vintage, my HTPC is a 2014 vintage. Results were exactly the same. Make MKV decrypted successfully, hand brake processed fine, end result was a special feature movie only.
#3 Post by Woodstock » Mon Jan 16, 2017 6:47 pm
Is this the edition that says "Lionsgate" on the packaging? You may have selected the wrong title, due to play list obfuscation. I decided to not bother with it because of the fake play list crap Lionsgate does with their titles.
kiszka6911
#4 Post by kiszka6911 » Tue Jan 17, 2017 4:27 pm
I think it is the Lionsgate version, I will check tonight when I get home, thanks. AJK
