I have a Lite-On DH-401S Blu-ray drive that MakeMKV does not find...No drive found error.
I am running Vista 32 and latest MakeMKV v1.3 Beta.
Do you support this Blu-Ray drive in your beta version 1.3?
Blu-Ray drive not Found
- Contact:
Re: Blu-Ray drive not Found
Hi Anna,
Please check that you have admin rights, because computer administrator privileges are required to run the beta version. This is limitation of Windows SCSI application programming interface. The full version of MakeMKV will not require administrator privileges to run.
Hope this will help
Hope this will help
See the newer post titled: Cannot access drive with AHCI on
2 of us so far have found we cannot be running in AHCI mode in order for MKV to access our media drives.
Yes!! That was it Dandirk...Wont work with AHCI...Thanks!
Don't thank me, thank the poster in the other thread. He found the issue, his work around just happened to work for me too.
- Contact:
Guys, can you please enable "log debug messages" in preferences dialog, switch back to AHCI, restart makemkv and see if it prints any messages in the log window at all when it does not find the drive?
FAILURE: Code 3221225653 at f+W}7OH4*4Qk[Z:213130674
FAILURE: Code 3221225653 at 41)ea%@3:K=Y!m6}:213130858
FAILURE: Code 0 at 41)ea%@3:K=Y!m6}:29394413
FAILURE: Code 0 at #o*BQ4Cu;q]hLun<8T_M_8rI/g:213130030
The program can't find any usable optical drives. The BETA version requires administrative privileges for drive access.
FAILURE: Code 3221225488 at (T(6+t|!LB*f+j:29394597
FAILURE: Code 3221225488 at RwwD;Q_IFF[ SUc(:213131180
FAILURE: Code 0 at RwwD;Q_IFF[ SUc(:29394275
FAILURE: Code 0 at ?){XNKr`]kNh^$3yu`q9%w!Kb5:29393493
FAILURE: Code 3221225653 at (T(6+t|!LB*f+j:29394597
FAILURE: Code 3221225653 at RwwD;Q_IFF[ SUc(:213131180
