Keeping Up With the Joneses
Cornstick
#1 Post by Cornstick » Fri Jan 13, 2017 5:40 am
Looks like it has Street Lock. When opening I get the error "BD+ code processed but no FUT's were obtained, errors may follow"
Sure enough, the rip is junk. However is plays fine on my 6+ year old Sony player.
Re: Keeping Up With the Joneses
#2 Post by Woodstock » Fri Jan 13, 2017 1:50 pm
Your error message indicates a newer version of BD+. Along with it, there should have been a path to a file with the information Mike needs to fix it, and instructions to send it to svq@makemkv.com for analysis.
Did you do that?
Cornstick
#3 Post by Cornstick » Fri Jan 13, 2017 3:58 pm
No.... I figured you would want the log file but I no instructions popped up. Only the error message. I will send it now.
Thanks.
#4 Post by Woodstock » Fri Jan 13, 2017 4:48 pm
BD+ changes on an almost monthly basis, with new releases. Getting copies of the files is always important.
Cornstick
#5 Post by Cornstick » Sat Jan 14, 2017 12:43 am
Is this something that will take a few days to sort out or just a few minutes?
#6 Post by Woodstock » Sat Jan 14, 2017 3:28 am
With BD+, it's when Mike has time to work on it. If you allow MakeMKV to contact the web server for updates, USUALLY within a week, it will just work.
Mike makes no announcements about BD+ unless something special is happening that will require an update to the basic program, instead of just an SVQ being issued.
(a little) more information can be found here: /svq/
