Error 'Internal error - Decryption error (411)' occured
gregjsmith
#1 Post by gregjsmith » Wed May 12, 2010 3:46 pm
I've seen this error on several disks, disks which were not reported to be problems. This time it was The 40 Year Old Virgin Bluray and MakeMKV quit with an internal error. Here's the debug code.
001003:0020 DEBUG: Code 0 at fX@tIDq'?'Op`%7(]ot7:29396184
002003:0000 Error 'Internal error - Decryption error (411)' occured while reading '/BDMV/STREAM/00162.m2ts' at offset '905969664'
001003:0020 DEBUG: Code 0 at 'BX28{\7%'TC,_CP:213136769
001003:0020 DEBUG: Code 117834139 at h0}e1|9Qmr K<%Hi(_:213132445
001003:0020 DEBUG: Code 117834139 at h0}e1|9Qmr K<%Hi(_:29393654
001003:0020 DEBUG: Code 0 at YGP3|+/N2X,;gH7mpA9q:213130628
001003:0020 DEBUG: Code 0 at -tdg!eg%+&exBFpiHj73:213129823
001003:0020 DEBUG: Code 0 at YGP3|+/N2X,;gH7mpA9q:213130513
001003:0020 DEBUG: Code 442368 at YGP3|+/N2X,;gH7mpA9q:213129639
001003:0020 DEBUG: Code 0 at <%\DHqVi1 >l`*^upDL<x:29397449
JPaneasy
Re: Error 'Internal error - Decryption error (411)' occured
#2 Post by JPaneasy » Wed Aug 25, 2010 4:52 am
I get the same error with Avatar blu ray. doesn't look like anyone helped you out here. did you solve the problem?
#3 Post by mike admin » Wed Aug 25, 2010 7:59 am
That looks like a problem with disc or drive. The data read seems to be garbage.
gregjsmith
#4 Post by gregjsmith » Wed Aug 25, 2010 11:11 am
It's been a physical media issue. I found the discs were dirty in most cases. My BluRay player can handle smudges pretty well the ripping software cannot. Cleaning the discs seems to have solved this problem every time.
