High memory usage, 600 MB
stax76
Why does it use so much memory? I use Win 7 x64 with only 2 GB memory so it might be problematic using other high memory applications in parallel.
Re: High memory usage, 600 MB
You may change amount of memory used for buffering in preferences.
stax76
Thanks, I'll try 256 MB.
There are some minor UI issues using 144 DPI, might be QT related.
http://msdn.microsoft.com/en-us/library ... 85%29.aspx
davidgreem
It is not possible if the system is perfectly working,you must check it out something is wrong with the system and check the buffer memory also.
stax76
What are you talking about?
Which process memory usage are you talking about, makemkv , makemkvcon or both?
stax76
@mike admin
Who do you mean, davidgreem or me? What is makemkvcon?
