Errors in Open Disc Log
davjen62
Post by davjen62 » Tue Jan 10, 2017 6:16 pm
I'm trying to set up a procedure that uses the log that's created when the disc is opened as an aid to documenting what's what on a particular disc. (As a backup in case I ever have to rip that disc again). I'm noticing that the log is not always correct. For example, a disc I'm working on right now has the following log entries:
MakeMKV v1.10.4 win(x64-release) started
File 00001.mpls was added as title #0
Title #00010.mpls has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00014.mpls was added as title #1
File 00015.mpls was added as title #2
Title #00016.mpls has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00018.mpls was added as title #3
File 00019.mpls was added as title #4
File 00002.mpls was added as title #5
File 00003.mpls was added as title #6
Title #00011.mpls has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00420.mpls was added as title #7
File 00421.mpls was added as title #8
Title 6 is correct, but title 7 is actually file 421.mpls. Title 8 is 422.mpls, and so on. Every entry from this point forward is shifted in this way. Anybody else trying to use this log to do anything that matters?
Re: Errors in Open Disc Log
Post by Woodstock » Tue Jan 10, 2017 6:32 pm
Send the log and files asked for in the FAQ link in my signature to support@makemkv.com so that Mike can look at them, please. That's really the only way to find out if it is correct or a problem.
