Batch File Question
DanielBme
Batch File Question
#1 Post by DanielBme » Mon Jan 09, 2017 11:40 pm
Hi, I'm new to MakeMKV and have a question. I have a bunch of blu-ray tv show discs that are stored on my NAS in blu-ray folder structure. I've ripped a few episodes successfully but was hoping to find a quicker way. Is there any way I can load up a number of disc folders and have them run overnight which allows me to select the tracks I need from each?
Re: Batch File Question
#2 Post by Woodstock » Tue Jan 10, 2017 1:18 am
Lots of choices, if the information is already decrypted.
Check the Advanced forum here, and you will see some scripts to automate using MakeMKV. They would work without decryption.
With a decrypted source, you can also use scripts found on the handbrake forum (forum.handbrake.fr) to automate re-encoding the files to be smaller, at the same time as converting them to MKV (or MP4) files.
DanielBme
#3 Post by DanielBme » Tue Jan 10, 2017 2:27 am
Ok, I'll take a look there. The disks have already been all decrypted.
