Batch File Question
DanielBme
Batch File Question
Post by DanielBme »
Hi, I'm new to MakeMKV and have a question. I have a bunch of blu-ray tv show discs that are stored on my NAS in blu-ray folder structure. I've ripped a few episodes successfully but was hoping to find a quicker way. Is there any way I can load up a number of disc folders and have them run overnight which allows me to select the tracks I need from each?
Re: Batch File Question
Lots of choices, if the information is already decrypted.
Check the Advanced forum here, and you will see some scripts to automate using MakeMKV. They would work without decryption.
With a decrypted source, you can also use scripts found on the handbrake forum (forum.handbrake.fr) to automate re-encoding the files to be smaller, at the same time as converting them to MKV (or MP4) files.
DanielBme
Post by DanielBme »
Ok, I'll take a look there. The disks have already been all decrypted.
