How to configure preference only with command line
-FX-RIDER-
Post by -FX-RIDER- » Sun May 09, 2010 2:37 pm
I'm using the new 1.5.5 beta on an minimal ubuntu karmic installation. I'm using just makemkvcon, but I can't use Avatar, because I can't configure the folders for makeMKV. Is it possible to use something like a configfile which is automatically used by makeMKV? I need to configure whre makeMKV can find the SQV package.
Re: How to configure preference only with command line
Post by mike admin » Mon May 10, 2010 8:06 am
The configuration file is ~/.MakeMKV/settings.conf . For svq path the setting name is bdplus_SvqDir . The easiest way would be edit preferences on another computer and copy the configuration file.
-FX-RIDER-
Post by -FX-RIDER- » Tue May 11, 2010 9:13 am
Hi mike,
thank you for the answer. Couldn't try it up to now. Can't you upload a "generic" config file which I could change for my purpose?
skittle
Post by skittle » Tue May 11, 2010 3:43 pm
this is what mine looks like
skittle@Skittle-PC:~/.MakeMKV$ cat settings.conf
# MakeMKV settings file, written by MakeMKV v1.5.5 beta linux(x64-release)
aacs_KeyFilesDir = ""
app_DestinationDir = ""
app_Key = "T-o4vIHFtFMG0O4H5u0NT40YJcRLnfXk2j1O0Yiy3O6YrwbHga7kWEYays4AS6MTK9h9"
app_ShowDebug = "1"
bdplus_DumpDir = ""
bdplus_SvqDir = "/home/skittle/.MakeMKV"
-FX-RIDER-
Post by -FX-RIDER- » Tue May 11, 2010 9:48 pm
Hi skittle,
thank you very much... worked like a charm.
Finally I'm able to watch Avatar...
You guys rock...
Problem solved!
MDrules
Post by MDrules » Tue Mar 12, 2013 11:58 pm
what is the syntax for setting automatic svq download?
MDrules
Post by MDrules » Wed Mar 13, 2013 1:11 am
I am guessing it is app_UpdateEnable = "1"
